1985 Rally Yellow Mk2 Coupe S G40
Choke cable and acc cable with clamp
elbo twisted round with no intercooler? :|
I might be able to get away with all types, as i can work sat morning then go down straight after and just have sunday off. but then its money thats the problem even if i can :lol:
  • Replies 553
  • Views 79.6k
  • grungeisdead
    grungeisdead
    Friday evenings endevaours started late so ended at 6am, back on it the next day about 1 and we were on the road a few hours later, after some smoke fuelled adventures! some pics before fitting the ra
i find it interesting because its in a mk2 and theres no evidence of the front panel being cut, the rad looks mighty short and theres either no intercooler fitted, or a standard one has been mashed into place.
food for thought anyway!
ill take 25 quid for the bits, cost me 45 for the choke cable, throttle cable, 2 throttle linkage adaptors and the pedal adaptor
Edited by grungeisdead
From what I can tell, there doesn't appear to be an IC. Wont do much for power, as intake temperatures will still be relatively high. The other option would be to use a charge air coooler that could be mounted on the inner wing of the passenger side. Charge air coolers are meant to be more efficient than intercoolers in terms of cooling.
I wouldn't like to comprehend how that charger would come out for a service on the above, either!
got a charge cooler, its still fitted on the mk3's bay at the minute, gotta take it out and fit it on the peril at some point.
I'm fitting an intercooler regardless, wouldnt want to run without one!
service the charger - drop the engine haha!
Drop the engine? Owwww hell no!
You can run without an IC and just run a charge cooler. Seen that done on Kam/Fluxco's Mark1 Derby G40, running the Rotrex charger. He resorted to that based on space issues in the Mark1 bay.
Certainly won't do it any harm running both though :-).
hmmmmmmm decisions decisions senor karlosfeatures!
Food for thought?
G40 engine in a mk2 coupe here. He might be able to give you some ideas?
Looks like his cooler sits behing the standard number plate location.... Not ideal but better than a cooler hanging out the front. If you could successfulyl relocate the plate without it looking naff?
Just brainstorming for you lol. Couldnt believe how small the IC was on my TDI until i took the bumper off and needed a magnifying glass to find it.
Yeah man I've seen that before, thats also another mk2 without any front panel cut out or removable section, which means servicing would be a mare!
Also not terribly keen on the intercooler positioning there either!
Found a couple of suitable looking intercoolers on ebay yesterday, just waiting to hear back the dimensions from the sellers to ascertain if they would be useful or not!
haha about yer tdi intercooler! will you need to get a bigger one when you uprate your engine?
what you on with this weekend? might try and get over!
No need to get a bigger cooler on the barge until up way over 150bhp and that would need a bigger turbo and a man size clutch which equals muchos dollar. I will be happy with 140bhp from the TDI.
I would remove whatever makes servicing the car easier. Unless you are going for a show bay which i highly doubt then who gives a funk as long as its nothing structural. How much different is the mk2 bay to the mk3 one? Is the crossmember sat where the pipework and cooler would go?
already removed enough to fit and remove charger, will be getting a cut out of a mk2 front panel, so i can make a removable section, ala standard mk2 g40's, ill get karlos to paint it up and rivet my identification plate onto the section.
the mk2 pays a good couple of inches shorter, which means you cant get the intercooler fitted in the regular location (just in front of the charger and intercooler)
you and i both know I'm not doing this to have a show worthy bay, thats not really my steez.
140bhp and bags of torque should do nicely sir!
Saf u amiture u need my skills to complete this beast ! Haha get it done lad !
Dragging your arse with this saf :lol: was the lift pump any good.
Still amassing some parts like.
Peteg40 was a true hero and sorted me out a perfect intercooler for the job so ill be fitting that tomorrow along with fuel pump assembly and lines.
Might see where I've got space for the charge cooler and get the boost guage and bits fitted!
Fuel pump loom should be with me next week thanks to big burt!
Also cleaned das peril for the first time in 8 months!
225113_10150231816846343_511441342_88754
Top stuff cant wait to see it finished.
saf man, was cool to meet you today... hope you get the mk2 back on the road soon :)
Was good to meet you too alex, n cheers daryl.
Painted up fuel pump assembly and built up ready to fit with intank pump tomorrow.
Fitted inector rail and mounted oil cooler in the wing, see pics
230052_10150233637121343_511441342_88966
227214_10150233637876343_511441342_88966
Also upon stripping the interior and carpets to lay the fuel pump loom, found a load of surface rust under the rear bench as it was sodden. Props to biglou for the wire brush steez and to karlos for the holesaw flex.
Removed a shitload of sound deadening too as it was soggy and weighed a tonne
good work buddy :) wont be long now!
Made provisions for intercooler
230513_10150234269611343_511441342_89039
229382_10150234330496343_511441342_89046
229491_10150234266971343_511441342_89039
Removed aquamist and guages from the mk3 to mount in the mk2.
Pics of subby
230816_10150234268286343_511441342_89039
Brakes
225825_10150234269356343_511441342_89039
The interior based fail boo. Gettin cleaned up, etch primered, 2k primed and painted yellow again. :-)
Think you can just see the intank pump
226176_10150234332126343_511441342_89046
229210_10150234331431343_511441342_89046
Fuel pump assembly fitted with self tappers, still gotta put clamp on for pump.
228444_10150234332061343_511441342_89046
some tidy work there saf,
i could do with a few holes in the front panel like that tbh
yesssss saf!, top work as always :D
Sound, PM incoming bro.
Engine looks at home in that bay, nice high-spec engine in a light mk2 should be pretty fun!
Well last weeks progress on the peril was interuppted by the arrival of another mk2 coupe, but back on the peril this week
got the fuel pump loom fitted today, along with with all the mk3 fuel lines, just need a few jubilees clamps to finish off the fuelling side of things
still a big list of things to do for saturday morning for the all types convoy!
* Jubilees for In-tank pump, accumulator & fuel rail
* Bleed brakes
* Tighten Driveshafts / Hub Nuts / Wheel Bolts
* Fit Centre Exhaust Rubber + Tighten Exhaust Clamps
* Make custom loom up for coil + fuel pump power
* Fit Boost Guage
* Holesaw holes for intercooler feeds
* Mount Intercooler and fit hoses
* Fit Radiator / Header Tank & Heater Matrix Hose
* Fit Toothed Pulley to charger / Fit Charger / Fit Oil Lines + Charger Earth
* Fit Toothed Belt & Tension Charger
* Fit HT Leads & Oil Change
* Fit Battery
* Tax
* Tracking
Only got tomorrow and friday evening to jump on it, so fingers crossed.
I'm still waiting on my replacement cylinder head from Popdragin, but I can change that any time!
Woop Woop
i have been following this for a while but not posted. the workmanship looks very good and can't wait to see videos of embarassing bmw's etc but please for the love of god get the rust sorted on the front, then it'll be the sex.
Front Panel & Rear Bench is being resprayed when its back on the road and I can get it down to a friends bodyshop.
Rust and looks really dont bother me, and my prep and painting efforts this year will be concentrated on the mk1, as I want that in a booth for the end of summer.
Workmanship is pikey haha =D just the way I like it, will try and get a video this weekend en route to All Types, complete with smoke-screen!
