1985 Rally Yellow Mk2 Coupe S G40
Absoloutly epic trip, would love to do a trip like that!
  • Replies 553
  • Views 80.1k
  • grungeisdead
    grungeisdead
    Friday evenings endevaours started late so ended at 6am, back on it the next day about 1 and we were on the road a few hours later, after some smoke fuelled adventures! some pics before fitting the ra
Sick! Bare jelly.
that looks like one hell of an experience!!
Looks awesome man, properly jealous!
cheers guys, just got the dilemma now as to which car to take to the 'ring next year.
updates on the peril
blew it up a while back playing with an S3, who was playing catchup. still yet to strip the engine down, the charger got stripped the day i got back but all the seals were fine, and I've taken the sump off and it wasnt full of metal shards which means I'm hoping i just popped the headgasket. got a rebuilt block so all it not lost if i have melted a piston !
That's well safe.
  • 4 months later...
After getting the peril back onto some wheels and refitting the rear shocks so I could roll the peril around I decided to whip off the head after 6 months off the road ( broke something whilst in front of an s3 at silly speeds )
564508_10150776629616343_511441342_11727
Holy moly!
555483_10150776629996343_511441342_11727
Slammed rear as there's no springs fitted at the moment, still have to repair the thread on my hnr kit before I can put them back on.
524682_10150776630496343_511441342_11727
Plan now is to whip the engine out
Split the box
Paint new block ( that's sitting in the boot ) and gearbox black
Fit new oil pump, water pump and toothed pulley to new block
Paint rear water pump
Replace the helix organically lined clutch with a 4 paddle helix I've got
Clean engine bay
Unwrap engine loom and extend some wires so they are a lot cleaner in the bay
Cut out additional sections of the front panel and cross member for better airflow
Mount aquamist kit
Ideally I'd like to give the bay a lick of paint, I'll see if we've got a compressor by then.
Body wise I need to
Strip out all seats and rear carpet
Remove the fibreglass repair on the battery tray we did 2 or 3 years ago and weld up
Redo the welding on the lower rear sill that was patched for the first mot it had in my ownership
Drop the tank, strip back the paint and rust from under the rear floor and axle mounts and check the state of the filler neck panels, repair if ness
Replace breather hose for something rubber with a grommet through the body panel
Zinc etch prime, paint and underseal the floor and all other welded areas
Fit my powder coated gt rear axle, new fuel tank, new in tank lift pump.
Reunderseal front and rear inner arches
Refit lower sill trims
Clean up spots of rust on front panel and edges of wings
Fit new inner door membranes
Only bits I need to buy is a bit of paint and a wideband lambda
Yeah man, dawned on me this week that I hadn't driven it in so long and I loved summer cruising in it!
Will be nice to get this and teggys comet blue on the road at the same time!
mmmm i need a g40 lump.... i want to g the comet blue s I'm getting
Ditto.
I will say Hi if I see you at the next manc:union meet Saf lol.
Edited by brightsideteeem
Yay for the weekend so more could commence.
Friday saw the interior coming out so I can inspect the floor, remove all the sound deadening and check for rust
Battery tray fibreglass removed exposing a standard rusty polo behaviour
Saturday saw the car stuck up on axle stands, wings, sill trims and arch trims and bumper removed
Handbrake cables, rear axle, rear axle mounts, fuel tank and rear half of exhaust removed
Crispy drivers side rear lower arch
Breather hole in the inner arch
Inside of filler flap
Tomorrow I'll start stripping back all the underseal on the rear floor and cut out all the bad metal.
Edited by grungeisdead
Eeeek! Good luck dude. I'll have to bob up at some point and see how you're getting on/lend a hand (Karl on Steve's account as I cba signing out).
Attacked some underseal today
Yeah karlie! Get involved!
Shes in fine fettle under all that underseal. The bottom of the A-post, wghere it joins the sill is usually a grot-trap, but she's faired very well there from what I can see. Viva la Peril!
I've got some very busy months ahead, balancing work with erm more work, but I shall endeavour to come up as soon as I can.
want to come visit the rents in southport and fill my rear 1/4's yet? :lol:
Dude! I haven't time to fart atm, nevermind, getting up to Southport :lol:. I'll be lucky if I can get up there before I head off on holiday :-(.
What did you find as the best way to removing all that underseal dude? Gonna be attacking mine soon.
Busy Beaver Karlos! No worries mate, I know how it is!
Yeah the lower bit of the sill had a bit of surface rust, and there is a lil bit of rust bubbling by the inner sill/floor join inside the car (the rusty bits i stopped you poking, but generally pretty pleased with the state of it under the underseal. that bit will get cut out too and ill be removing all the bitumen crap off the floor on the inside!
Max -
Been using a wire brush on a grinder for the inner wing, although its not hard work, its just time consuming! wire brushes are also very aggressive on the lips of metal and will take metal away if your not careful.
I also had a go with a few different chisels when the metal had warmed up via the wire brushing, so i think ill be buying a heatgun tonight, as hopefully the main top layer will just peel straight off with the chisel, leaving the wire brush just to clean up the remnants.
Going to try white spirits when I've done it all over to see if that can dissolve the last bits of crap left.
I'm not looking forward to doing under the car with a wire brush. I seen this product on the internet - MBX Metal Blaster or Bristle Blaster, looks absolutely amazing for doing underseal and cleaning up steel but its 400 quid! So i'm hoping all of us in the unit can chip in, because itll only be a 1er each.
Regarding products ill be using on the bare metal, I've decided on Rustbuster Epoxy Mastic 121, but cant decide whether to put that straight onto the bare metal, or if I should acid etch prime it with UPol first.
I can find amazing reviews of epoxy mastic, but nothing to state if anyone has used any product on the metal before using epoxy (bar using fe123 rust convertor, to turn any existing rust into iron tannate)
Just a heads up on the etch primer. UPOL is available in a 1 litre reday to use tin that you can run through a spray gun. We've been using it on Dennis to great effect. It's also much better value than the 400ml aerosols as by volume it contains far more etch primer, as a great proportion of the 400ml in the aerosol is taken up by propellants. Iirc we paid circa £13 for this 1 litre tin from a paint supplies place, versus the £18 they were selling the aerosol equivalent at.
aye i need to buy a compressor and spray gun then grrrrrrrrr.
the epoxy mastic i can just paint on with a brush which does me nicely!
Yeah i've had a go before with a wire brush cup on the grinder, what diameter are you using? and is it brass or steel wire?
i ask because the bigger it is, the harder it is to control and your more likely to snag it on something and it pull the grinder out of grasp! Something you definetly don't want to happen when your stripping it all from underneath!
Edited by MaxMax
Twisted wire knot cup brush is what i use. last alot longer than them open strand jobbies.
Yeah deffo! , snag a lot more though if you get the big ones!
used a twisted wire steel circular brush. think it was around 115mm on a 4.5 inch grinder.
I've had a grinder go flying before a few times, interesting to say the least!
for the underneath I'm going to get the heatgun on the boot floor from inside and peel off as much as i can with chisesls and scrapers
Probably the best way to do it. Definetly wouldn't get under there with a grinder.
I've had one go across my knuckles with a wire brush on before, it fucking kills!
yeah i remember a grinding disc shattering and missing my balls by about 2 inches.
homemade vasectomy ftl!
and i would get under a car with a grinder, i am a scary bastard
Today's endeavours on both front inner wings
