1985 Rally Yellow Mk2 Coupe S G40
Met a friend, first time they have met in 24 years after being born on the same production run on the same back way back when.
My car was born 90 cars or so before 86c's
  • Replies 553
  • Views 80.1k
  • grungeisdead
    grungeisdead
    Friday evenings endevaours started late so ended at 6am, back on it the next day about 1 and we were on the road a few hours later, after some smoke fuelled adventures! some pics before fitting the ra
pm me a proper picture dude, my phone is ghey.
thanks man, they were ace in white but so much less of a pain to keep clean with black inserts!
and it doesnt need a respray you gayor =P
got some rivets at the weekend so if I'm feeling energetic this week i might refit them.
Edited by grungeisdead
You need to rock a go-ped on the back of yours Saf!!!
haha no no I'm dangerous enough on 4 wheels thank you, let alone 2 or 6 ;]
mmmm
8-)
couldnt resist trying on the throttle bodies =D
argllllllllllh
sweet project man!
cheers maxamillian
Well the parts pile is getting there, so far got the following sorted
Mk3 Flywheel & 5 Speed Anti Roll Bar - Karl_CLCoupe
CEG 5 Speed Box - Nick_S
G-Ladersiete ARB Blocks, Powerflex Inner&Outer TCA Bushes, MH Coil, Dizzy, TCi unit and loom - Karl6n
CBR600's
Will be picking everything up next week and hopefully going to try and get it in by the middle of next month.
Looking top!
You not going for 900's now then?
no was speaking to mikey and he says the 600s have more progressive needles than the 900s which make it more suited to the valver, his jets are drilled to 1.70mm
can you try and mod the arb blocks to fit with your subframe to move the subby down a bit to clear your sump?
Looks cool :) Is gonna sounds awesome with the ITB's 8-)
Shotgun a ride :lol:
nay laddie this beasty will be rocking carbs, got some cbr600s en route.
and shotgun your wallet for go go juice =]
Ah touche carbs FTW :D
And yer il pop some motion-potion in there for you :thumbsup:
aye waiting for all the bits really, hopefully this weekend ill be able to fit the vw2s discs and pads from the golf, fit the glader blocks and the tca polybushes so thats out the way.
and the main thing I'm waiting on with no definate date is the gearbox nick_s is selling, as once i get that i can clean it up paint it and then see if i can get away with the mk3 gearbox, mk4 flywheel and mk4 starter, otherwise ill swap the flywheel for a mk3 jobbie that karl is sorting me out, and use a mk2 or 3 starter motay.
then when the engine is ready to rock and I've decided on which fuel pump bike or car one to use, ill bop it in at the house over a weekend, humers kindly offered me the use of his crane if i give him prior notice so job will be a good un.
wanna get it done sooner rather than later now as i need more power now so the daily cruise is a little less laborious
cant find me camera so no piccy updates, but this weekend just gone saw the following fitted
Gladersiete ARB Blocks
Powerflex Inner & Outer TCA Bushes
New TCA (1 side)
VW2's from the Mk1 Golf GTI
239mm Drilled Black Diamond Discs
Pagid Pads
Also converted the HK lump over to electronic ignition from points, with a new coil, tci unit and dizzy.
Picked up the CEG Gearbox off Nick_S this evening so i will be cleaning it up and painting it tomorrow evening
Still need to source the correct Mk2 Dizzy that will fit the AFH head, source the fuel pump and get the engine mounting plate made up, although i can work without that and fit that at a later point should it come to it.
I'm also going to try and use the Mk4 flywheel and Mk4 starter motor, and see if it can be done, and if its not fruitful then i have a spare mk3 flywheel.
Fingers crossed everything will be here by the weekend after next as that is going to the weekend I'm going to attempt it!
Also need to replace the clutch cable as its started creaking at me and its due to snap any minute soon =/
Sounds like your really making progress :thumbsup: Cant wait to see it finished etc :p
well well well, moved the crashbot as its been sold to vw-nay who came down and lent a hand, and unearthed some treasures!
first noticed a tci unit, then attached to it the correct coil and wiring...
i thought there must be the dizzy around here somewhere, but to be honest, i have no idea at all where this loom came from. i certainly didnt buy it thats for sure, maybe it came with the huge amount of spares i got with the lupolo.
but alas a bit of a search revealed the correct dizzy 030 905 205 A
epic win.
also when i started emptying the crashbot, i unearthed several things id forgotten i owned, pleased by a working gt steering damper, so that will go one day in the week as they are a piece of piss to fit.
also nearly took out the windscreen! 50mph+bonnet not closed properly=potential fail
shes wearing a couple of battle scars now but just very small superficial paint damage, a localised touch up with a rub down, some zinc etch primer n top coat and itll be reet, but i do need new bonnet arm jobbies
well as i finally found my camera lead, time for some pictures
so, in d-town on the windiest day known to man.
reverse rake in full effect
bye bye postage stamps, hello gti stoppers
vice like grip
poiple bushes
greenery
the afh dizzy vs the mk2 dizzy with electronic ignition (there are two types, this will fit a HK)
and so it did fit a HK to replace the old points and condensor
el mascot/battle scar
we were all set for a cut n shut after a play with a 9 inch angle grinder
CEG 5 speed box off nick_s, in a first wet coat of por15 black velvet after a clean up
correct mk2 dizzy part number 030 905 205 A or B
picture showing clearance of water housing, the little take off on it gets in the way slightly so it cant be advanced anymore. it could be taken off and blanked and tapped elsewhere if it causes a problem
hengine - note they are lupo gti leads so too short for the dizzy and no king lead as theywould attach to a coil pack on the side of the head
Looking good safamonn 8-)
When you planning to get it in there?
To big carbs like that you have to have even bigger balls..... nuf said!
We all love safs big balls :ninja:
id really like to do it next weekend but I'm still waiting on carbs and exhaust in the post, and still have to get a fuel pump and the engine plate made up.
tomorrow i need swap the alternator pulleys and fit it to the engine
but before I'm allowed to do the engine conversion, i have to get my tracking done, fit new rear shoes, bearings, replace a wheel cylinder and drill out a snapped bleed nipple on a front calipers!
but youve reminded me to get some bits ordered from gsf tomo
balls of steel mate chickin fuckin nugget woop woop
oh and new exhaust to arrive soon, that will get mated to the gti decat downpipe. not too keen on the motorbike can, will be looking to get a bastuck style tip welded on but just gettin something stainless was my main priority and cant argue at 40 quid =]
http://i116.photobucket.com/albums/o25/lov.../Picture007.jpg
http://i116.photobucket.com/albums/o25/lov.../Picture008.jpg
http://i116.photobucket.com/albums/o25/lov.../Picture006.jpg
http://i116.photobucket.com/albums/o25/lov.../Picture009.jpg
brap brap,
new exhaust fitted, still needs some fettling but looks sweet and fits really well. top bargain for 40 quid.
will get a bastuck style tip welded on at some point but happy for the time being
