vibe/audiobahn amp/sub
Vibe slick A3 amp
4 channel
1300 max
bout 6 month old, perfect working order. no end caps
ran the below sub and a set of mb quart discus components in my jetta perfectly, sounded mint.
£70
Audiobahn Aw120T 12" sub in custom box
i built the box to the exact specs for that sub using all the specs and computer progs to plan it.
(its a vented box)
its tuned to 32.4Hz +/-1. Its a BIG box, 3.3cb ft, its about 20" wide, 15"deep and 16" high i think. can measure if needed
it isnt as fast as ported boxes for bloody speed niche or that kind of music but it hits very low. isnt slow by any meausre but dont expect it to be as fast as a little tiny sealed subbox. with a good set of components amp'd up front it sounds mint
subs perfect, box is built well but the carpetting its fucking shoddy
amps currently screwed to side but can be removed no problem
£60
both for £120
located sheffield can travel.
need this gone ASAP
  • Views 183
