5 x Refurbished/Polished/Laquered 14x6 MK1 MR2 4x100 Teardrops
Here for sale I have a set of 5 MK1 MR2 / AW11 teardrop wheels which I have refurbished myself using orbitals sanders, paint stripper, metal polish, a machine polisher and 2K paints from a spray gun:
The Process:
Curb Damage and brake dust:
Sanding and stripping the faces:
Wheels prepped and ready for high build primer:
Wheels in high build primer:
Wheels in black basecoat:
Front of a wheel after paint, sanding and polishing:
Wheels after machine polishing and lacquering:
I am open to offers on these wheels. One of the centre caps is missing and the wheel which was used as a spare had a very nasty curb mark in which required removal with an angle grinder so there is a slight up and down gradient on one of the rims but the metal is smooth, polished and lacquered to a high standard.
To fit a VW centre bore they will need to be bored from 54mm - 57mm.
I can arrange a courier to deliver these wheels at the cost of 50 pounds, however if you would like to collect I am based in Lutterworth, Leicestershire which is 1 mile from M1 junction 20.
Thanks - Jimmy - 07921 928 674
  • Views 425
