How To Remove Side/Rub/Bump Strips
Hi, This is my guide to removing the side strips off a polo 6n
You will need:
- A Measure Jug
- A Kettle
- Fishing Line
- Towel
- Cloth
- Turbs
- Screwdriver
- First :
Fill The Measuring Jug With Boiled Water Or Warm Water Depending On Colour Off Car
Pour The Water Over The Strips And Keep Doing This Until One Of The Edges Wobbles Abit
- Second :
Get Fishing Line A Place Behind Strips A Pull Towards Front Of Car And Work Your Way Up Ina Cutting Motion
Your Fishing May Snap A Couple Of Times
- Third :
Do This Until The Strip Falls Off
Then Cut A Srewdriver Or Something I Used My Finger Nail And Drag It Across The Black Stuff So It Like Tears
Then Get Your Turbs And Soak The Black Stuff And Leave For A Couple Of Mins
- Fourth :
This Is Where The Hard Work Starts
Get Your Towel And Start To Rub The Black Stuff And It Should Start To Come Off
Do This Till Its Removed Then U May Be Left Over With A Mark Wear The Strip Was You Can Remove This With Turbs But Takes Ages
I Would Advise A Resin Polish Or Like Tar Remover Polish
I Have Some Pics Of It Before, During And After It Took A While Cause Alll I Had Was Turbs :(
Will Has To Get Some Resin Polish
I Hope This Helps Some People ! :thumbsup:
James
  • Views 780
