MY MK1 G60 conversion - job lot
Due to having lack of time & space and too many other projects (MK2-VR6T) on the go at the moment i need to sell my MK1 G60 project, which i'm sure i will regret.
**** Note: I have all the body panels ****
I've had the car for almost 4 years, and have been stock piling parts for the conversion which have totalled to at least £6k's worth. Including hard to get hold of south african parts *****Including a citi golf dash conversion) I basically have pretty much everthing needed bar a few minor parts to complete the project.......
Here is most of the bits for the MK1 - there is more tho.
NOTE: Anyone coming to buy this will need a large van / trailer to take away !!!
It would be an ideal buy for a body/paint or interior retrimmer.........as these are the only 2 major things the car has to have done.
The G60 donor car, was Dubmeisters Demo Car when the TH mono's 1st come out. I still have some of the history for the car..........but if you want to know anymore about it, get in contact with the old owner @ dubmeister, cause aparantley he spent a fortune on the engine - which i found out from someone after buying it. Previous owner didn't really know much about the car......i bought the car as damaged/written off, the previous owner had smash on passenger corner and bent the chassis up.
The Base car is a 1983 Y-reg Mk1 1.1c (non sunroof - stronger) - i have the V5 document also.
The shell itself is in very good condition for the year, there is rust in usual places:
Front corner of sills, r/arches, f/wing arch, back panel (have all the repair panels + new Genuine wings).......small surface rust here and there. The underneath is pretty solid, small amounts of surface rust again but will come off when doing underbody restoration when removing underseal with wire wheel - was going to get rotisary and do it properley (can buy kits on ebay for £160)
The vehicle has been dismantled into shell form, but all parts bolts/nuts etc have been bagged and marked.
Here is a photochop, of what i wanted it to look like: (shout out to alex with his original photo of his top MK1 to make this chop possible :) )
Might as well start listing all the bits: (pics at the bottom)
BODY:
1983 Mk1 1.1c – non sunroof – Shell (engine mount moved)
Have all the glass & seals - will include a new windscreen in deal from my supplier
4 litres of 2K Paint (better than waterbased) – LA7T – VW Steel Grey (new passat range)
2x New Genuine Front Wings (obsolete)
Hadrians repair panels (New):
2x rear arches, 2x Sills, Rear Panel, O/S inner arch+filler cap (bought just in case its gone)
New Genuine plate holder
New Genuine tailgate strut
New FK crystal smoked front indicators
New APR 100% Carbon Fibre F1 mirrors (£100)
New Genuine Outer Door window seals (hockey sticks) (obsolete)
New Performance Trim Carbon Fibre arch spats (£110)
New FK crystal X-hair headlamps
**** New – South African Genuine VW/Hella – Smoked/red rear lenses + bulb holders ****
MK1 inner arch liners (set)
Grilles:
New Genuine centre section with black badge (obsolete)
New Pattern centre section + end headlamp surrounds
Used – Gti Red strip grille – needs painting
New Bumpers (front & rear) – GSF
New ½ finished Stainless Steel fuel filler pipe – Pipe bent, just needs brackets.
MK2 Wiper motor
WHEELS + TYRES:
Fully refurbished- just need bolting together - BBS RM’s from G60 (£400)
"original silver type finish" Powdercoated baskets & threads freshly chased – by Mike “The Polisher” (£220)
Schmidt Radinox 1.5” + 2” dishes (£500)
New bolts, but would recommend getting some stainless ones.
4 x Brand New 165/50/15 Bridgestones (£250)
1x Spare – BBS RM001 7x15” 4x100 ET25 57.1
ENGINE / FUELING etc:
1H Golf Rallye – G60 engine – Rebuilt 10k ago (contact ex-owner @ dubmeister for details)
New Cambelt + tensioner, Top end gaskets (not head gasket), lifters, water housings
Stage 4 charger + 68mm pulley (no history on charger – but would have been rebuilt with stg 4 & engine)
MK1 n/s chassis engine mount modified to G60 block water jacket plate
Performance ignition leads
Flywheel skimmed + New Sachs “sporting” G60 clutch & release bearing (£140)
New Sump, gasket, plug
Raceland Stainless steel 4-2-1 manifold (supersprint copy) (£140)
New Genuine G60 crank bolt
New MK1 Diesel sandwich g/box mount
Spare: G60 distributor, coil, leads
Golf G60 intank lift pump, Fuel pump + filter housing
New Bosch Platinum G60 spark plugs (£40)
New Bosch G60 fuel filter
New OEM quality Water pump
New G60 oil filter
New Genuine Mercedes Sprinter intercooler (£140)
New Corrado G60 Radiator + New Genuine water outlet flange & gasket
Corrado G60 Fan + cowling
Late spec G60 inlet manifold – better flow………(current one ported as well)
New – Genuine Windage tray (from 4cyl Tdi) (£60+)
MK2 Fusebox, G60 wiring Loom, ECU (chipped), TRACKER (needs re-activating), Clifford Thatch 1 Alarm/Immobiliser
New Custom 02a Galvanised gearbox mounts – n/s leg + rear – (from ebay.de) (£120)
3 spare – 1H Rallye pistons
Spare G60 engine loom + fan over-run loom
New – Facet lift pump/inline feed pump kit
MK1 golf complete vehicle wiring loom
Golf Rallye 180 degree charger outlet + OE metal gasket
New’ish G60 Alternator
Polished Alloy 90 degree charger inlet + JR cone filter
New – MK1 Fuel Tank
2 spare – Genuine G60 block water jacket plate o-ring gaskets
Mk2 water expansion tank, G60 top hose + brackets for Mk1
Spare G60 fuel rail + injectors
Used: MK1 1.1 Carb Fuel Tank + Mk1 Gti Fuel tank + pipes
MK1 GTi Fuel pump wiring loom
SUSPENSION:
New FK Konigsport (fully adjustable) MK1 coilovers (£550)
New Front strut top mounts
New Steering rack boots
New Rear strut top mounts
New Polyurethane rack mount bushes
New Track rod + Tie rods (both adjustable – unlike original mk1)
New Ball joints
New MK1 GTi steering rack
New Polished Alloy upper rear strut brace
New Carbon Fibre + Alloy front upper strut brace (£120)
Spare MK1 steering coloumn + pedal assembly
New Lower arms + bushes + brackets kit
Powder Coated – RED – Gti Anti roll bars
New Genuine front ARB under-body mounts/brackets (obsolete)
Used (good condition – just need painting) – Rear ARB brackets (obsolete)
New Genuine ARB bushes
New Genuine rear axle bush kit + axle bolts (over £120 worth)
DRIVETRAIN/BRAKES:
02A Gearboxes (cable change): mix match ratios ????
MK3 TDI – ASD
PASSAT TDI – CTN
CORDOBA 2.0 16v - ???
CORRADO 1.8 16v – AGC
*** 02j *** Seat Toledo TDI - EBF code
NEW OBX ATB torque biasing Diff (£300) – just need bolt kit
New Genuine gearbox electronic speed sensor
New Genuine Mk2 r/disc shields
New outer CV boots
New G60 brake M/C 22.2mm
New OEM quality FAG – Gearbox slave cylinder (£60)
New “special” CNC machined G60/S2 caliper brackets (£120)
New inner CV boots
New PAGID G60 F/Brake pads + MK2 R/pads
New BREMBO MK2 r/brake discs
New Mk2 rear wheel bearing kits
New Mk1 front wheel bearing kits
100mm Cabby/Caddy driveshafts
G60 Calipers + carriers
“Rare” Scirrocco 16v brake compensator valves that fit to the Master cylinder
New BREMBO 280mm G60 discs
New Scirrocco 16v handbrake cables
MK2 rear stub axles
MK4 cable change shifter + cables
MK4 Golf/Bora alloy rear callipers
MK2 9” Servo
MK1 brake linkage
INTERIOR:
**** South African Citi Golf **** Dashboard conversion with bolt in brackets & updated heater/climate control + centre console (£650shipped)
Original Mk1 dash / interior parts
New pedal rubbers
Spare MK2 fusebox
New – OPTION TUNING – smoked/light up 52mm gauges: Voltmeter, Air/fuel ratio, Oil temp, Boost
MK1 Momo steering boss
MK2 Big collar splined steering coloumn adapter
MK1 headlining + wire supports
Corrado Rear seat conversion + seat frame and brackets cut out of donor (need welding in mk1)
MK4 golf “recaro style” sport seats from TDiPD, modified bases (fully adjustable height)
MK2 r/carpet section for template of custom carpet piece with corrado seat conversion
New Lupo Gti leather 5spd gearknob £50
MISC:
Misc. MK1, MK2 – bolts, brackets, pipes, hoses, starters, cables, bolt, nuts, etc,etc,etc……
Corrado Bentley factory manual on CD in PDF format
Full MK1 G60 conversion guide on CD in PDF format with wiring diagrams
The only bits still needed are (NOT INCLUDED !!)
Body prep + Respray
Retrim + carpet/headling (Newton commercial)
10pc side body strips/moldings – black
Alloy filler cap
custom exhaust system - which when needed i can get you one done @ powerflow exeter for cost price
SNS stg. 5 G60 chip (highly recommended !!!)
G-werks Mk1 world cup front mount (old autocavan design)
Genuine blue water temp sensor
High pressure Braided fuel lines
Lower strut brace
“In-theme” late spec Steering wheel to match dash - Mk7 polo/MK5 golf/2009 audi A3 ???
MK5 Golf / TT centre console to keep in theme with dash
So for someone looking for a full on project and doesn't want the hassle of having to go out looking for all the parts needed to to produce a show car, this is what you need.......
I'm looking for £4500 for the lot - hell its worth that in just parts alone, but i don't have time to list and sell seperately, so would prefer it went as a whole job lot and see the car being turned into something i visioned.
Please PM me with any questions..................and please no silly offers, or P/X's.......want the cash to put towards the other projects
LOCATION - EXETER,Devon
Sticking this advert up for someone i know, so if interestes please contact John via email "johnreynolds_2004@yahoo.co.uk"
  • Views 537
