mk4 valver.....1996 .............only 250quid
hello
rite baught this witha snapped cambelt.
100k+ miles
no mot or tax
5dr
dragon green
tidy interior
not bad exterior
I've stripped the head of had it skimmed and lapped in 8 new valves.also fitted a new cambelt and cleraned the bay e.c.t
put it back together and it didnt start the throttle body is buzzing whe i put the ignition on. it did start but the exhaust gases were very black meaning ti much fuel.it basically given up on it and am alot more intrested in swapping the engine in my jett to 1.6 and bike carbs so its not gin to get fixed anytime soon.
I'm guessing it needs a new throttle body or programing. i also have the correct resistance readings to measure somwhere but not done that either
comes with a set of fk ak coilovers need one new adjuster ring on the front all the other 7 adjust freely and no leeks 2 white vlaver alloys and 2 loose vlaver alloys all with goood tyres. on tyre is on a steel and one is loose.
all the bay is clean ans shiney and i grit blasted the rocker cover,exhaust heat shield and painted em black with red insert writing on the doch 16v part
cleans up well which is why iahvent broken it.
250quid...bargain but need the space and cannot be bothered with it haha
very dirty in pics though thats from when it first arrived at mine
il try get some better ones after I'm back from the polo show
Edited by polo.6n.max
  • Views 344
