Pioneer 4-channel amp
Got a Pioneer GM6000f amp that I don't need anymore. Got some scratches and rub marks on the face of it but don't affect performance or anything.
Features
* Specifications
* Peak Music Power 480 Watts
* Number of Channels 4
* Load Impedance Capability 2~8 Ohm (Stereo), 4~8 Ohm (Bridged)
* Continuous Power (4 ohm) 50W x 4
* Continuous Power (2 ohm) 60W x 4
* Continuous Power Bridged (4 ohm) 120W x 2
* Frequency Response 10Hz ~ 50kHz
* Total Harmonic Distortion 0.008%
* Signal-to-Noise Ratio 95dB
* Dimensions 12" x 2-3/8" x 12-3/4"
* Features
* Bridgeable
* Channel # Capability 2/3/4
* PWM Regulated MOSFET Power Supply
* Screw-Type Speaker Terminals
* Balanced Isolator Input Circuit
* RCA Inputs 4 Channel
* RCA Outputs (Pass Thru)
* Input Level Control Hi-Volt (400mV ~ 6.5V)
* Built-in Crossover Variable LPF/HPF (40~120Hz, -12dB/Oct.) (Front/Rear Independent)
£35 delivered to your door.
  • Views 206
