Bike carbs piccy inside - Rolling Road monday :-D
no worries mate...ill post up the results and suggestions on monday...as i said I'm hoping that the power/torque increase is good enough that i dont need to worry about any of this.
I've got all the parts bar the mk2 loom if i need them anyway...hopefully ben at corten-miller wont suggest too much and ill be a happy dubber getting ready to increase it more with a full exhaust system.
am just hoping that my setup may help people with their quest for bike carbs and maybe inspire people also lol
at least I'm at the fore running of the new breed of bike carbed polos lol
  • Replies 48
  • Views 4.7k
Nice to see - particularly the intuition with the throttle bracket.
The ignition's clearly not right though,you're missing big torque down low,i hope you find it because it should be at its best below 3.5k,not above it.
any suggestions mate?? I mean you are the club polo bike carb guru lol
it does pull straight off the bat but then seems too stutter a little and then pulls more after, it is only a minor stutter.
I really have no idea about anything too do with cars especially ignitions etc so any suggestion would be appreciated
yep if your sticking with a dizzy you will need one with a vac advance on .pref with hall sender .but has anybody used the nz ign set up personall tidyer than the mk2. and dont forget you will need 4 vacume pipes to even things out .and just to get people thinking what about running a fixed gt dizzy with a mk2 golf 16v knock ign unit I'm not sure on the map tho and then theres loads of waste spark ign ecu's out there and you can then kick your dizzy over next doors fence
ok i have no idea what you just said whatsoever lol :-D
ill see what the guys at corten miller suggest on monday and see what the graphs say...i dont see what the problem with the standard kit is, it starts and runs fine, fuel consumptions probably a bit s**t but then its a 1.6, its crap anyway and youve got to make sacrifices for power gain
I dont do ECU's.
I'm an auto sparky by trade, i have to...... mix of the old and new ftw
I'm with mikey, ecu's are a ballache.
while everything else is telling it what it should be doing, it goes off and does its own thing.
they look a really nice setup sean, is it a big noticible pull in power? yours is 75bhp standard aint it?
might be worth looking into this for mine, how do you no what carbs just bolt straight on?
cheers for the info guys but lets not get too lost on the technical stuff in this thread lol :-D
james - yeh it gives decent pull, just waiting for the graph on monday to hopefully show gains and prove its not just my imagination lol
yeh mines 75bhp standard...I thought yours was a gti?? i wouldnt know what carbs bolt on as i bought the whole kit but i think the general consensus is that a 1.4 - 1.6 suit 600 cc bike carbs.
the easiest way would be too ask the techno boffs above you in this thread lol
lookin good, did you put them on urself mate?? was it easy?? does it sound nice!!
Sounds gorgeous mate lol, sound even better when the exhaust system is sorted too
i got a mate to put them on as i had no idea what too do but to be honest, in hind sight i could probably have done it just as easily!!!
ill tell you monday if its worth it or not :-D lol
sound pal, let us know then
what you meen is. the ecu does what it should do but you dont understand what or why it is doing it .......you use a pc .it does its job but do you know why its doing it ..............dont knock what you dont understand
The problem with the usual injection set-up is that there's too much to go wrong. Throttle position,temp,oxygen or Lamda sensors for example mis-read and then you get the wrong fueling.
A simple system (which in the case of my own car) is proving to be as economical as any other circa 130bhp petrol hatch (name one that does 40-60mpg),probably catalyst friendly (i may run one yet),and reliable (all ignition parts are believed 21 years old,and counting).
When i last ran with an ECU it surprisingly sailed an mot emissions test - surprisingly because this wasn't reflected at the pumps,the thing drank fuel considerably worse,with seemingly all of its original 125bhp.
Not that previous ECU controlled hot hatches I've owned were any better - the Polo is the most efficient car I've had for untold years. Ever,in 8v form.
The aftermarket computer-mappable styrtems look pretty good. I like the concept of being able to map out my own ignition curve,setting it up on a dyno to get it spot-on to fuel usage.
But i dont really see the point,when i can just use a simple ignition system (whether manufacturer or settings-adjustable aftermarket),and adjust its curve to suit the cam.
Its not gonna be changed once set up,other than seasonal/altitude air changes,or wanting the best of all worlds in one drive. Putting half a degree on a dizzy takes like nine seconds (changing a setting is quicker on some electronic full-unit dizzies) but i dont because I've found no need.
A mappable system would still need to be altered for this as well,so I'm struggling to see the point on a road car,unless you can rig it up to the throttle position sensor and have a curve which bends to the demand on the throttle.
Even still,the argument for that looks weak.
So just what is the point we're missing,Bort?
I do understand what its doing, its just the fact that at the time it was doing it wrong :lol: all sorted now ddo.
Mikey sums it up well. if one thing is out then you have to search through everything else, even when vag-com or VW tools pinpoint the problem it doesnt always sort it, and as cars get more and more ECU based its going to get worse.
As an example:
Mk3 polo SPI system is practically a ECU controlled carb with readings coming from temp sender, lamba and TPS - it then changes fuelling and throttle idle postion to suit. Very simple, and easy to fix as it has the minimum of parts, and normally its obvious were the problem lies
Chevrolet Aveo: had one as a courtesy car 1.4 16v engine (it was shit), engine bay was a mass of sensors, practically everything had a sensor, surprised that it didnt take the drivers heartbeat as well.
Washed it the day before I gave it back and the ECU light came on, didnt have the software to deal with it so called the AA out, took the AA guy 3 hours to decipher what the diagnostic reader (kept showing up after clearing the codes) was showing as the fault and took us another 2 hours to find said sensor, turned out that the sensor plug had been knocked somehow and water had got in, we redried it and put it back in, all ok. moved it a short distance to the drive ECU light again and car fails to even turn over or read from diagnostic, so he phones the dealership, tells them about the plug and that we sorted that, then about the other issue their reply to the second problem was that it was our fault because we hadnt let it run long enough between starting and stopping WTF!!! and the ECU apparently gets confused and seriously over fuels, but their is a sensor that detects this and cuts power to stop you starting a flooded engine.
Bit of an essay but sums up quite well why ECU's are a bit crappy. :lol:
Edited by Cymro
I'm not a typer I'm a do er ......as most know i dont say a lot and spell wrong .i am only realy talking about aftermarket ecu's i have wired emerald and megajolt .both do there jobs amazingly .no loose dizzy cap .no worn rotor arm to name some probs .i appresiate efi and respect it .I'm old school and love carbs but when i was looking at dizzy's ie vacume advance your stuck with what you get... pay £300 for a day on the rolers and what can they do ............re jet if they know bike carbs ............but with megerjolt things are different ..................this is a post about carbs and i will only mention the ign ecu .but efi ie (emerald ) to say one can do most things apart from suck your dick...............I'm the first to say i will do it my way ..................................................................Borts back x x x
Hey up, we're in trouble then!!!!!!
Call me, I missed you...... :nod:
yay bort is back,miss you fella :)
you have so much knowledge its unreal, at tht shire meet when u was explaining the carb set ups that dan could possibly run i think u lost us but amazed us at the same time :)
well you all totally lost me with this lol
well off topic :lol:
basicly at low revs the ignition map/timing (call it what you wish) will be different tan at high revs .if it is a vacume dizzy or ecu that does this it dosent matter .but running fixed ign timing is only any good if your running between a set rev band ie track use.................I'm using a ecu and i just defended it ................but have love for talking carbs ...........not to say I'm not messing with efi
I'm not a typer I'm a do er ......as most know i dont say a lot and spell wrong .i am only realy talking about aftermarket ecu's i have wired emerald and megajolt .both do there jobs amazingly .no loose dizzy cap .no worn rotor arm to name some probs .i appresiate efi and respect it .I'm old school and love carbs but when i was looking at dizzy's ie vacume advance your stuck with what you get... pay £300 for a day on the rolers and what can they do ............re jet if they know bike carbs ............but with megerjolt things are different ..................this is a post about carbs and i will only mention the ign ecu .but efi ie (emerald ) to say one can do most things apart from suck your dick............... I'm the first to say i will do it my way ..................................................................Borts back x x x
Not the first,but its the pioneers and just general leaders who push things forward and try things.
So whilst i dont find rotor point wear or dizzy cap fixture a problem,and would never spend three ton on a tune,i can appreciate the motivation of doing things your own way :thumbsup:
When you use carbs on the injection engine the ECU reverts to a very safe and poor efficiency/power ignition curve because the ECU no longer has all the info it needs to calculate the best advance. no throttle position etc.
Edited by Tommo32
