1981 Mk1 Polo 1.6 16V - Project
Been offered something I cant really refuse and I need to release some funds, so for a limited time only the entire project is available for £1995.
OR £1495 without Chrome Bumpers, ITBS or Inlet Manifold but the car will come with the standard Lupo GTI Injection setup, and could be run with an ecu/immob and keys (circa 200 pounds)
Saf
07816 002 453
Yousafn@gmail.com
X Reg 1981 Mk1 Polo
Engine:
43k 1598cc 1.6 16V (Lupo GTI - 123bhp)
5-Speed Box
R1 Independant Throttle Bodies
Custom Inlet Manifold
Suspension:
Fully Adjustable Front Wishbones
Rose jointed Camber adjusting top mounts
Strengthened strut tops
Lupo Gti Front Shocks and Springs
Mk1 Polo Steering Arms
Lupo Stub Axles
Mk3 GT Powdercoated Rear Axle
Shell Modifications:
Bulkhead removed
Seam welded
Seat Runners Removed
Modified Gearbox Mount for Lupo Gearbox
Brakes: Lupo GTI 256mm Brakes
Exterior -
Satin Black Front Panel & Bonnet
Diamond Silver Everywhere else
chrome bumpers, rear nos with nos trim
all original door handles and boot lock with original key
rear panel has been resprayed diamond silver, front of the wings have been resprayed diamond silver, bonnet is satin blacked.
The Front Panel/Rear Panel/Floor Pan & Engine Bay have all been zinc etch primed and por-15d.
New copper brake lines are required throughout, they are supplied with the sale, as well as a brand new master cylinder.
still on logbook as 1.1 iirc
Build Thread
http://z3.invisionfree.com/Mk1_Polo_Club/i...p?showtopic=587
midpainting
current state
Jobs to do.
Braking
Measure and fit solid brake lines
Fit braided hoses
Remove and paint stub axles, back plates and drums from GT rear axle
New Wheel Bearings for Rear
Fit rear axle
Fit Handbrake
Fit Handbrake Cable
Fit Front Brakes
Fit Master Cylinder
Engine
Get GT Alternator and change pulley wheel
Fit Alternator
Fit ITBs
Clean Inner CVs and Regrease.
Fit Driveshafts
Fit throttle cable for ITBS
Replace Oil
Plumb coolant system
Fit header tank
Fit Downpipe
Fit Exhaust
Gearbox
Replace bell housing gasket
Replace Gearbox oil
Get Hydraulic Clutch Parts
Refit Clutch Lever to Gearbox
Attach shifter to gearbox
Fuelling
Fit Mk2 Golf Fuel Pump & Accumulator
Run braided fuel lines inside car
Wiring
Install wiring for radiator, rear lights, front lights
Welding
Drivers Wing
Box section for seat rails
Things to Get :-
Emerald
Welding For Seats
Exhaust
:smoke:
  • Views 298
