Fitting bike carbs onto a mk2/3 & 6n
hiya megajolt
  • Replies 938
  • Views 184.6k
  • Gash pics of my set up, note lack of ecu and heater matrix :) Ant
  • MiNoR cOnFuSiOn
    MiNoR cOnFuSiOn
    no, no and no.. you dont cut/bend springs... lots of people seem to like stretching there springs out (idiot superbike owners) thinking it will help with things... as far as springs go.. you want to
  • Then bigger,from a 600-900cc,though that's not to say bigger is better universally. They have vaccum-operated flat slides,which govern the throttle dependant of what the engine can draw at any time,so
Came to turn my engine over yesterday, everything connected up as it should be, and fuel started pissing out of the t piece in the carbs on the fuel-in. Now I think it may have a split in the t piece as its leaking from where it goes in. Are these t pieces available from bike dealers and how easy are they to replace (I have very basic mech skills)
They are gsxr600's by the way
Any help appreciated muchly!
just any t picce the correct size for pipe diameter will be fine mate, pref metal however some plastic type ones are designed to be used in fuel, just might degrade and go brittle unlike metal ones :)
unless you mean the t pieces mounted between the carbs to fuel each float bowl?
Yup those ones :(
Yup those ones :(
Don't have frame no. Or the age of the bike they came off so dunno what to do.. buy another set of carbs being the easy option??
(1) 052905205L ignition distributor / F 86-E-150 001>> / GT
(1) 036905205Q ignition distributor / use for 2 hole attachment: 052 905 289 A / HB:FORMEL E
(1) 052905205M ignition distributor / F 86-E-150 001>> / HK
(1) 052905237 X ignition distributor / to be used for: / F 86-E-150 001>> 052 905 205 M / HK
(1) 052905205F ignition distributor / F >> 86-E-150 000 / GL
(1) 052905205Q ignition distributor / F 86-E-150 001>> / GL
(1) 052905205H ignition distributor / F >> 86-E-150 000 / GK
(1) 052905205R ignition distributor / F 86-E-150 001>> / GK
(1) 030905205R ignition distributor / MH,NU,2G
(1) 030905237DX ignition distributor / to be used for: 030 905 205 R / MH,NU,2G
(1) 030905205Q ignition distributor / AAK,HZ
(1) 030905237EX ignition distributor / to be used for: 030 905 205 Q / AAK,HZ
(1) 030905205S ignition distributor / NZ
(1) 030905237FX ignition distributor / to be used for: 030 905 205 S / NZ
(1) 030905205T ignition distributor / 3F,PY
(1) 030905237 X ignition distributor / to be used for: 030 905 205 T / 3F,PY
Out of all them, the ones it bold are the only ones from a hyrdo headed mk2 engine, that runs vacuum advance.
The MH and the 2G engines being the 1.3 engines, the NU i have no idea, never heard of it. Definetly isn't a 1.05 or anything.
Might be the deisel?
diesel? vac advanced, spark...diesel?
Yup those ones :(
Could be the O-rings on them or your pressure is way too high.
Check the carbs are securely bolted together
Yup those ones :(
Well I've got an electric facet pump 1-5psi i think? You see when I put the fuel hose onto the t piece i heard a very quiet crack? So i thought it might have split due to my over persuasion of fuel pipe fittage! I'll take the carbs off tomorrow and split them and check the o-rings too.
Messaged the guy I bought them off (phataz1) and he's checking to see if he has the frame no. :)
What carbs are they? Keihin? There should be some identifying codes somewhere.
Report back and we'll help identify them.
Yes they are Keihin I'm pretty sure, cant check til tomorrow night as i'm away with work but i'll let you know what i find. Cheers mucker :)
Right I've got the carbs off again, they are Keihin, i found printed on the side '26E0 JFT' and 'CVK' was printed somewhere else.
All i know is they are off a GSXR 600
:smoke:
aha. You've got a keihin CVK carb setup then.
take it apart, see what (if anything) is broken, and get googling. Don't wast your time finding part until you know you need them.
Thanks :thumbsup:
hi i have got some cbr 600 f carbs and want to know how do i go about fitting the indiviual air filters on these adn there is no way of holding them into place
thanks
Show us what you got.
this is what I've got obviously where the trumpets and air box bolts onto with a rubber gasket
sorry for crap picture one i took to help when i reassembled them
What filters?
Ok the question is can you get the indiviual air filters to fit these carbs if so how and if possible can I have pictures
ebay > search: Carb Filter socks
Have you got the trumpets? as you will need those to hold the filters.
Yeh got the standard trumpets an like half the air box but the airbox plastics and there's like a gold coloured piece of steel with 4 bolt holes in each corner to bolt to the carbs there is one of those for each trumpet aswell how do I hole the trumpet on with out the plastic airbox bit
think you might need the plastic bit.
Oh ok could I replace it with a strip of metal to tidy it up if not I was thinking about making a airbox to house a filter with a cold air feed too it aswell I am an apprentice welder/fabricator so I should be able to knock something up lol
If you do make your own then you may get a few requests. :lol:
