Polo G40 for sale
Thinking of selling the G40 this week as i need the cash for the house
CURRENT SPEC
1000 miles since engine rebuild
1308cc carl schmit pistons
PSD big valve flowed head
Newman eaton spec cam from PSD
Lightened and balanced
Jabba R1 charger
65mm pulley
Green induction kit
Boost return mod
Dewedged throttle body
Gt inlet manifold
Pro-speed custom stainless steel exhaust
VAG de-cat pipe
G60 green injectors
Lightweight slim line fan
Performance polos map#0005
Koni dampening adjustable suspension
Tarox monza 239mm drilled and grooved discs
Aw tracksport stainless steel boost pipes
Minteq pads
Custom oil catch tank
13" RA BBS alloys fitted with firestone tyres all round
Chassis strengthening bar under gearbox
NEW PARTS FITTED LAST 1000 MILES
New leads
New plugs
New oil pump
New rings
New head bolts
New head gasket
New timing belt
New timing belt pulley
New crank oil seal
New crank plate gasket
New oil filter
New syntha silver oil
I'm the 2nd owner from new, an elderly couple from berkshire had it before me. I have owned the car for around 8 years now. Its currently on 101k miles but only 1k since engine rebuild. I dont have service history on the charge but it has Jabba R1 and number scribed inside so i might ring them to find out when it was last done. Boosts fine at 1 bar. It has about 8 months MOT left and a couple of months tax left.
I have entered the car in 3 show and shines in Volksfest wales and have rossettes for 1st, 2nd and 3rd place.
It has been off the road the last 3 years as i have been rebuilding it slowly when funds permitted. Had a few issues when i first got it back running but sorted now and running fine. Dont want to sell it now as its running very well but i really need the money to go towards the house. Would consider a cheaper car plus cash my way.
The only things that need to be done to get the car as i want it is refit the roof lining under the window rubbers, if i get the chance i will do this. the roof lining is all in place but just not in the rubbers. The centre console is slightly loose and the boost gauge is loosely fitted in the centre console. The rear window is a lightweight window from plastics4perfomance but i do have the proper glass rear window available. There are a few surface scratches which i will try to t-cut out this week.
ALSO AVAILABLE IN SALE
Large AW tracksport intercooler
Eaton m45 charger
AMD 55mm pulley
PSD Custom remap for eaton setup
Spare new VAG front bumper
Orange front indicators
LPG conversion kit
Polished Mk4 rocker cover
The only thing missing is the charger bracket to refit the eaton setup if you wanted to run the eaton instead of the g-lader.
I'm looking for £3100 for car as it is or £3500 with the spares ONO
Car is located in Port Talbot, South wales
i will add pics when i clean it this week
  • Views 469
