Lowering Names
how big a notch, its pretty much sat on it as it is, i'd imagine it would still hit it when going over bumps... might just have to man it up and raise it..
  • Replies 32
  • Views 4k
Pics of how low it is??
Rake = nose down and complements other features that come to create "stance" such as wheel widths, tyre sizes, poke and tuck, camber etc.
Reverse rake = nose up and is usually found on saxo's and 106's a lot due to having a rear beam which is hard to measure up to be lowered appropriately so most just slam it all the way down and try to get the front down as much as poss.
That's cos most pug and saxo owners just lower the rear beam with the notches technique which can only go like 40mm, 80mm etc rather than removing the torsion bars completely so can lower however much you want.
danny6N - yep notching the chassis leg is the only way, requires welding etc. Simple if you are capable with stuff like that.
clicky pics
Not actually that low, 15s though int it, its as low as it can go without said driveshaft problem becoming a major issue (bar putting it on 14s)
If a car is lower at the back than the front i'd call it SHIT.
Tbh, it depends what you mean by lower (arch gap, sill height)
To make a car sit right, you want the sills to be parallel to the ground.
Danny6n is like a twin car of trackrats!
Always known it as rake and reverse rake too. Reverse rake IMO fails hard! I always determine rake by sill height and not arch gap. My E36 is pretty much parallel sill wise. I think with my breadvan I wouldn't mind a bit of nose down action :)
If you've been around long enough to remember, mines looked like this for over 3 years... probably been on cp for twoish. And trackrats is relatively new. Touchy subject :lol:
evidence lol clicky
Edited by danny6n
