I could cry...
Finally, the Crossmember and Lower front panel arrived from Beevers and its seems that they are the wrong parts!!!! The Crossmember is about 50cm short and the Lower Front Panel looks nothing like it should and is a 10th of the size. Absolutely gutted.
Can anyone spell out to me what the name of the 2 parts are in the red boxes in the picture below??
  • Views 768
id call the top bit..slam panel or closing panel
the lower bit... front panel , although the thin bit under the grille is seperate i think
