Best Cheap Modifications
Pickaxe + bonnet = speed holes.
think i might have seen that on a corsa :\
Simpsons....
  • Replies 109
  • Views 15.2k
  • tinting front headlights <5 pounds for a tin of black hammerite And running lights in front indys - free with £20 tinted indys from germany, nice surprise when i opened the box!
Simpsons....
mates corsa got bonnet like an scooby with vents here there and everywhere lol
Drilled airbox = free
Thats been proven on four different cars in a row,on a rolling road,to reduce power. Usually makes it sound better though - and that makes the car feel faster.
The last thing you want is to increase the temperature of the air going into the engine,because it reduces the oxygen per unit of air - and that's what you do by drilling the airbox.
What do you class as cheap?
Leather reclining bucket seats - £321 8-)
Its a valid point - but three ton is more than some Polos cost (though such leathers can totally sort the atmosphere of the interior),yet less than some pay with just six weeks finance. So what margin indeed. Well,how about one that pays for itself..?
I wasnt gonna add it but its as valid as any in my experience - bike carbs.
I bought and fitted mine,originally,for under £100.
They made the engine considerably more powerful than standard,and the freebie bit - i got relatively amazing fuel economy. So i got my money back,when i wouldnt have done with other upgrades.
A few G40 owners have given me some stick over the subject,as if it was gonna affect their residual values or something,but I've done it,and they haven't. I have nothing to prove or gain. I'm not in business here,noone knows me. And as for proof - its a hollow claim from a random on the web,so its a 'take it or leave it' message to everyone.
Heh looking at the TVR Sagaris I'd say that's possible lol...
What sort of price would it cost to get bike carbs running on a Mk3 1.05? Plz pm me ^^.
You not gonna come to the RR day Mikey?
Not to prove a point, just it'd be good to see yours run..
what engine is that for?
1.0 litre :unibrow:
Yeah i think so,made promises before but i run out of money late january due to Christmas monthly wages. The Clubpolo RR session is at a ridiculous time of year for those on monthly pay.. Financial situ is a bit different this year (less costs,not more money lol) so I'm hoping to make it. Got a RR session in the post already,so i'll have some figures before long anyway - but they'll be on retarded cam timing due to a compound head gasket,so wont be brilliant.
[The last thing you want is to increase the temperature of the air going into the engine,because it reduces the oxygen per unit of air - and that's what you do by drilling the airbox.
Depends what units you measure air in. Technically you should measure everything as mass, in which case there would be exactly the same amount of oxygen whether hot or cold. But if you were to measure it as a volume at a given pressure then your statement would be correct, as hotter air is less dense, meaning there is less of everything in a given space, oxygen included. Although there isnt really a unit for that.
What he said :paranoid:
lol
just done this its great lol
I try to avoid PM as it seems waseful,when everyone could see the info instead - so CBR400F carbs,they'll cost a bully. Try ebay or your local bike breakers. Flanges,brackets and tubing can be had for another bully. Probably from B&Q's plumbing dept but i made my flanges at work and the wire-reinforced tubing was an offcut of an industrial order,so i got lucky. You'll need to use your head to avoid paying over three ton for a fancy custom manifold and Samco hoses,but if you do enough mileage even that could pay for itself. Not with a thrashy 1.0 though,i believe you need the medium stroke 1391cc ABD 1.4 Golf engine to keep the revs down and get better economy (mine on CBR600s was more economical than my 3yo Seicento Sporting).
More details in the bike carb topic,this has been hijacked enough.
Technically,yeah,but the units measured are simply the cylinder full at BDC. If its hot air,same fuel,you'll have less burn (and subsequently run richer,unless you have a fuel system that compensates) than if its colder air,where you'll have more oxygen to burn. Also,whatever the compression ratio,you'll have a higher compression with cold air than you'll have with hot.
Simply fix a pipe from the intake to the grille (not aimed but a sealed passage) and you'll get more kick. In the case of EFi the oxygen sensor will detect more oxygen and add the extra fuel required.
It wont sound any better,though..
Ok then, cheers mate :).
i've used a drain pipe 90 degree bend for my cold air filter kit, works great! £2 b & q and no it hasn't melted!
Imacculate Mk2 door cards, carpets, seats, and VW mats in place of my ripped, collapsed and disgustingly dirty Mk3 interior. Looks way better IMO. FREE:)
And 6n steelies for nothing with good tyres, replacing knackered Mk3 wheels..
Clear front indies £6 from a breakers yard.
16v rear lights, swapped for my 8v ones.
Clear side repeaters, free.
Set of alloys, given them and got them professionally done black for free.
Dewiper, Free
Cut the curly end bit off my 6n exhaust, only did it so that it could not be seen under the bumper, but it really makes it sound a lot better as well.
Sprayed the front badge black, £3 for paint
Debadged, free.
Thats basically everything i've done to my polo, once its been lowered it'll look pretty nice, and so far I've spent about £10 on bits. Colour coded a few interior bits but i had the paint lieing around anyway. Coilovers are going to be the most expensive mod, although i do fancy some leather seats.
how do you stiffen suspension with engine oil!
On my 340 because it's the old style of suspension like the MK2 Polos etc. where the leg is all as one with the hub n stuff, took the shock all apart, drained the old oil out and refilled with the same amount of engine oil lol. Worked an absolute treat on my Volvo!
Then for the rear I fitted uprated Land Rover gas shocks :D
landy shocks and engine oil in the shocks of a volvo 340 gta be a drift nut!!!!!
:lol: You know this! Along with no interior, a welded diff and a clio engine on bike carbs 8-)
random question how do u wire up them inde light coz i got them on my indecators cheers
snip the thinnest wire on your headlight plug, crimp the two ends of this and one of your indi wires together, then either do the same with the white wire and the other indy wire or stick a lug on the second indy wire and bolt it to the wing.
they will then come on with your sidelights
Could you do roughly the same thing with a 4 light Mk2 grill? Join up the wires to the inner 2 lights come on with main beam and not just full beam?
what? main beam is full beam ! you can have them on any other time or you will blind people
Ha, yeah, idiot i am. I think i meant sidelights, maybe :ninja:
So... you want your spot lamps on with sidelights? As in, the little bulbs that you only use for other people to see you, not the other way round, like if its raining really bad or something?
I think you need to get a build thread up for this, sounds like a hoot.
