Mk4 to Mk5 Dash Change Problems
right I've just bought a polo :D and it has had the dash out of a mk5 put in! however the mk5 clocks arnt wired up and it doesn't have the heaters and i was just wondering if anyone had done this conversion and wondered if the Mk5 heaters could be wired up to a mk4 loom and same with clocks? i presume clocks will just be snip existin wires and chock block new connector on but does anyone know if this works? is easy? all dials on clocks work etc?
hope someone can help :D cheers
  • Views 678
