6n engine bays
oftttt. Christian that looks the mutts. :)
DO IT!!! :D
Kuszpit :)
  • Replies 59
  • Views 7.8k
Ooof!
what paint did you use to paint the rocker cover black mate?
thanks Yasser
hi mate,
i sanded it down and then coated it over and over with black satin high temp heat paint used for BBQ's etc and then used a red touch up to do the writing etc.
the paint has been chipped off on the left hand side and under the DOHC 16v because when fitting my new rocker cover gasket i had it laid face down whilst trying to remove the old gasket so it chipped off on the corner of the table. :S
Hope this helps mate. :)
Kuszpit :)
chrispy if you dont make your bay look like that before next years show season then you're a gay :p
Edited by andypandy
Chrispy get that rocker cover polished up man!
no way :p
i have a better idea, just need to sort it out!
nice example here
(L)
That is All!
there's mine
:lol::lol: find it soo funny how you show this off so much when you didnt even do it.
my old polo back in 07
when he first got the car, it was no where near as shiney as that... theres been some hours gone into getting that finish :/
looks same to me
see the pitting marks on the inlet?
yeah... not anymore.
woooo amazing work
Who cares if it's done by someone else anyway? Saved him a lot of hassle and probably cheaper if he bought it already in the car... win win IMO
I think i've made it look a fair bit different now.
Lost the chav shit "Race Spec" leads and replaced them with OEM ones
Replaced the plastic BOV with a Forge Motorsport Split-R (Polished that, as the original finish still had milling marks)
Replaced the "Carbon" oil cap with a decent metal one
Replaced all the other caps in the bay with new VW ones
Replaced the PAS bottle cap with one from Forge Motorsport
Thats not to mention half of the mechanical work i've had to do on the car to get it up to scratch.
New plugs, leads, coilpack, crank position sensor, coolant temperature sensor, new pads all round, clutch pedal repaired and strengthened, gear linkages sorted, new sump, new vac line for the brake servos in the boot, new boost pipe clips, new gearbox dogbone mount and new top mounts and track rod ends. I've probably forgot something tbh.
So before you go mouthing off saying i've done nothing, it might be an idea to get your facts straight?
owned
My old 1.0 litre bay...
quick question how do you get your rocker cover like that ? really like that!!
polish mate :)
Picture I took tonight, nowt special!
you put your brake servo in the boot panda?
there are two servo's in the boot. I'm not a fan of that setup tbh, but it works. I may go for a servoless setup though with a rally pedal box.
my polo, cant find the original photo?
and a close up
off topic but what kind of brake setup r u actually running on you are 6n panda??
Kuszpit :)
16v fronts with uprated disks and pads, braided lines right through.
mk5 gti back axle, disk conversion.
for now... until...
mmm sexy. cheers panda, was just curious :)
Kuszpit :)
well your all here sticking up you immaculate engines, let me show you what I'm running!!!
serious power within that beast :lol:
Edited by jbird2009
