Is it legal ?
is it legal to smooth my side repeters off ?
  • Replies 15
  • Views 1.7k
no but you would need them on your mirrors or similar as you need by law them on the side of the car
Its a MOT failure if the car comes with them on as standerd.
U need to be able to see indicaors from the side of the car, so on a 6n your fine to smoothe ure side repeaters as u can see your fronts from the side :-)
your all talking rubbish (except sam) =D lol
i haven't had side repeaters on the last two of my cars and theyve both gone through MOTs....he drives a mk4 and the front indicators are visible from the front and side so therefore it is legal!!!
so the answer mate is YES =D
Edited by seanvw
I worked in a mot station for over a year mate..I've seen cars come and go with no side indicators and fail purley because they are meant to be there in the 1st place! and its not if its visable from the side it if its visable when you parrel to the boot and 3ft away from the car.. ill draw you a picture lol.
lol mine went through fine and was not a dodgy MOT at all so I'm talking from experience also =D plus mk4s look so much better without them
look
Mate I'm talking technical terms here! Some mot testers wont care , most probably wont... but it should have them.
yes u are meant 2 have them.
...pop down ure local mot test center n see what they say. ;)
david.
Edited by riskie
grrrrrrreat advice! :roll:
david.
Spot the side repeaters on my mates VR6. :)
You spotted them Yet?
Look at the front little bumper strip :D There in there. And he has them behind the front grilles at the bottom on the front :)
Kuszpit :)
Edited by Kuszpit
I'm sure i've heard that flashing orange lights have to be visible, as per diagram, but you need to remove the wiring for the repeaters..
Edited by essex_dub
You saying it isn't legal and then drawing a diagram showing how it could be legal.
As per your own diagram if you can see the indicators and the orginal side indicators have been removed then it should pass an MOT.
However why totally remove them they are somthing that can avoid you being involved in an accident. Think of a way to keep them yet still get the style you are looking for. That golf is a perfect example.
what about newer cars that have them in the mirrors, i'm sure i can think of a few examples that you could not see from the diagram above so they wouldn't pass?
Olly
My mk2 doesnt have side repeaters as standard, werent fitted in the first place, and it is noticable on roundabouts when your going round to the right that people start to move because they see no indicator until I'm actually facing them rather than seeing it early on the side of the car.
Id go for smoothing and locating one elsewhere, mirror etc
