Ported cylinder heads - pictures of your ports
it's a 1.6 AEE head
exaust
inlet
dit this before my bike carb conversion
what kind of gains did you achieve with the aee after the work?
can't say
did this with a 272' camshaft and bike carbs conversion
  • Replies 35
  • Views 13k
it's a 1.6 AEE head
exaust
inlet
can't say
aahhh kool :-)
i have the standard aee and as the heads coming off soon i want to find some more torque while I'm at it,and a couple of horses
will have it ported n polished,but not sure on cams,was thinking 268,then either gt fueling or bike carbs?
it's a 1.6 AEE head
exaust
inlet
can't say
aahhh kool :-)
only polish the exaust ports
here are 2 movies of my car
from 120KM/H till 200+ in 5th gear
from 0 to 180 KM/H
its in a polo 1f so it's a little lighter than your polo
  • 2 years later...
BUMP lets revive this thread! Its quite interesting To read. Lets see your work people!
Mine looks like the AEE one above but did myself :)
My mate said he had a go on his 205.. The way he did it was to have 4 cups of water the same. And poor them into the cylinder head and mark off the levle . Although this would allow you to have the same size ports the shape could still be diff.. God knows gow he blocked the ports off :/ lol
With that valves......? :lol:
iv been told to do this with the combustion chamber for balancing. only instead of using cups of water id use syringes marked with the CC's for the exact amount.
Yeah equal volumes.
Did it with my head.
Piece of glass with a hole. Smear of Vaseline to head surface. Will using a burette and voluming oil.
Also gives an indication of if your valves are lapped properly too
  • 13 years later...
Hi everyone,
I have a 1.3 Polo engine with a hydraulic lifter cylinder head. On inspection, I noticed:
  • a large lump in the exhaust bowl
  • a small bump in the intake port
In one photo, you can still see a small edge on the right side, but in another photo where more light is shone, it’s completely gone.
My question: is it safe to remove these completely when porting, or is it better to leave some material? I’ve seen tuning companies like KWL Motorsport and TKMotorsport remove this (look at the photos), but I’d like to hear your experience before I start on the head.
I’m mainly aiming for maximum power between 4–8k rpm. Any tips or experiences with hydro head modifications are welcome!
Have you shortened the valve guides?
