Winter Pack - G40
Heated washer jets 191955986A
Can someone else confirm that this is the correct vag number also does any one know how these fit? wiring wise etc etc
Jake
  • Replies 32
  • Views 3.7k
the washer jets just clip in the usual location jake.
u can use the original hose feed but the wiring needs a wee black clip ( can steel them off golfs passats) to hold it. wires up as described earlier. :thumbsup: can see the 2 connectors white and black if you take the wee panel out below the glovebox.
and runs along the bonnet like this:
theres a picture of the wiring loom on ETKA
Edited by genesisGT
cheers for the pics Rich , re wiring i was just wondering if they just plug in or how work etc
you can still buy the loom, think its under £40 in vat from VW but it will be a order up 2 week wait bit i think. but it is plug and play. with the exception of one rubber grommet you might need to put in boiling water to squeeze stuff through the middle of it then fit it back in the bulk head.
or if your lucky in the scrappy cut as much as you can off a golf or passat (passats better the wires longer) and its a positive (feed) and a negative (earth)
can do it the easy way which is earth it under the ECU or onto the bonnet! and a feed direct from the fusebox!
but the other way to under the dash and the 3 connectors is the factory way.
if you take the panel out under the glove box you cant miss them. the black feed is up near the fusebox and is just hanging there. the earth is just into the big white T shaped item where most of the dash earths go.
Edited by genesisGT
How are these switched? Sounds like it's ignition switched? How does the factory way switch them?
I've had a set from a Passat sitting in a box for about 4 years that I never got round to fitting, I might get round to it soon if I can find them again...
factory way is they are live the instant the ignitions on, so the switch if you want to call it that is the ignition key yeah.
they dont draw much current as its just a wee heater element.
but you could switch them off the foglight switch as on most cars position one does bugger all and the connectors right next to the ECU with a live and earth waiting there.
the winter pack was a pack vw offered from the factory its listed in a number of there brochures.
but as usual vw broke there own rules and if you had money and wanted just 1 of them they did it which is why some cars have strange options on them.
Edited by genesisGT
If anyone's interested, I'll scan the official options list for the Series 2F and post here this week.
Rich
Yes please!
Here you go - the UK sheet of factory-fitted options can be found here: http://www.polodriver.com/vwpolo2foptions.pdf
(About a 1MB download.)
Heated washer jets were £22.03, while headlamp washers were £171.35. Fog lights came in at £228.88...
Also have a Polo Accessories (1990-1994 2F) brochure whiich lists things like electric windows, steering wheels and alloys plus all the VAG options/dealer options at the time.
Thanks for the info on how the heated jets work genesisGT - I did wonder if they were off the rear screen heater, but now know not!
Rich
Very interesting, thanks Rich.
