reluctant to start
Hi folks
Having a bit of trouble getting the car started on cold mornings.
When i turn the key it sounds as though the engine is trying to turn treacle its very laboured and will turn over very slowly and wont start.
If i then squirt a bit of easy start or a bit of petrol into the carb, it still turns over slowly untill the fuel is taken in and then it sounds as though you have just introduced a load of lube to the pistons as it wisses round and then starts up fine.
What can the problem be
Gav
  • Views 479
