Boot drain hole?
Hi, I (or rather the missus) have a 1999 T reg 6N2 Polo and we've discovered water collecting in the boot 'well' where the spare wheel sits. There are three holes in the spare wheel 'well' stopped up with rubber bungs. One had slightly perished and I suspect that is how the water may have got in - I have resealed it. However, I noticed that there is also a smaller hole directly under the spindle that is used to secure the spare wheel that appears to have no stopper. Is this supposed to be the case? Will it not let water in? Or is it actually a drain hole?
Would appreciate if someone could comfirm whether this hole should be stoppered up.
Sqwim
  • Views 603
