Hello from a total Polo Noob!
didt want to start a new thread for my noob questions, can anyone help with the ones above?
I got my headunit wired in ok, but radio reception seesm cack, and the right dash tweeter isnt working! :crybaby:
anyone know how to get the tweetr out to check it?
thanks
  • Replies 30
  • Views 2.9k
hey and welcome :) cant help with your questions but your car reminds me of my first car about 3 yrs ago!
welcome :-)
remove the grille and the tweeter should just pop out with a flat screwdriver,its wired up to the door speaker so twin connections
why not treat it to some new components? good upgrade
and I'm sure the aeirial has a booster,check the aerial cable behind the stereo as theres a section with a blue wire going to it? like a rem wire for an amp. phone. ect? is on mine.... if not you may need a new one
welcome :-)
Could I use the existing wiring to put components in?
There were a couple of extra wires coming from the Polo that Ididnt wire up, i think one was to link the Dash dimmer to the
lights on the head unit, not sure what the other one was for!
i only kept the wires to the door woofers as it was too much hassle replacing that tbh,but youll need extra wire because of the crossovers and where you place them.
as for the tweeter youll notice a new one is smaller,you can either modify the exsisting one and fit the new one in it which someone did on here?!,or get some thin ply to plug the hole in the dash and fit it in the ply,glue down paint black ect.failing that you could fit the tweeter in the door,sure theres a sticky for it on here...
not totally sure on the aerial booster,when i got my polo i went about fitting a headunit and amp and couldnt find the rem wire,it was connected to the aerial cable,i just spliced it to get my amp feed,its a blue wire
Edited by gaz2000
rem wire?
