WONT REV ECU AGAIN.
HI,
CAN ANY ONE HELP!! I HAVE 51 POLO 1.0 STARTS OK AND WILL TICK OVER FINE.FAULT IN MEMORY THROTTLE PEDAL SWITCH ALL TESTED OK INC WIRES.
REPLACED UNIT ANY WAY.TRACED FAULT TO PIN 7 ON THE ECU.REPLACED ECU AND ALL WAS WELL FOR A WEEK.NOW ITS DONE THE SAME.
I HAVE CHECK THE WIREING UNDER THE DASH AND IN THE ENGING BAY.CHECKED LAMBDA PROBES,MAP SENSOR,THROTTLE ETC ALL ARE FINE AT TIME OF TEST.
CAN ANY HELP PLEASE!! :?
  • Views 585
