You know you have a mk4 polo when.....
when it's garenteed to of been in a crash at some point.
  • Replies 112
  • Views 7.8k
When the exhaust is fine one day and randomly falls in half the day after so you have to drive a KA to uni tomorrow :-( hatefull car, drives like a jelly!
:ninja: :ninja:
..................You sell it and go Jap...
watch the members decline now! :lol:
Makes sense as I dont like jelly! Unlucky man think everyone here feels for you having to drive a KA
Edited by bondbill2k2
when you make body contact with a door and the top of the door stabs you with its sharpness :lol:
:lol: oh my god the shoulder jab!!
i get it all the time! :lol:
and when your doors freeze shut when your in a rush to get to work u eventually open it then it decides its not gonna shut so you spend ages tryna get the fucker in reverse, hold the door shut and turn all at once then you smarten up realise its never gonna happen and go back to bed!
the rear wiper arm snaps when you lift it up to clean the back screen
the boot lock seizes and you can't turn the key
the front subframe bolts snap when you try and take the subframe off
the sills rust where the join is under the door
Edited by Mister D
When the day you are in a rush your locks deside to freeze cause it was so fucking cold through the night so you have to go and boil the kettle which makes you even later for work :x
When your 1.0l engine sounds like a household hover !!
- When you've owned the car 10 minutes and the timing belt snaps
- When you've just bought your 4th gearbox in 12 months
- When you think that one of these days the central locking pump is going to wheeze its last
- When you lower it and the subframe catches on a man hole writting it off
- When you poke about a bit as it only looks like surface and put a screwdriver right through the sill
- When you realise that VW were bastards by puttin 185/55's on the 16v wheels - 2x as much as a 185/60
- When you realise you could get more in the boot of your mk3
- When you find that being a newer Spanish Polo doesnt make its build quailyt any better
- When the sunvisor falls off randomly
- When the boot lock seizes
- When the studs in the boolt lid that hold your number plate on rust through and your plate drops off when you close the boot
- When your suspension squeaks in pain cause you run so low
- When your CAT is squashed flat and chokes your car intil it dies
- When the coil pack explodes and leaves you stuck in the middle of no where
Holy shit andy you've had no luck with that Mk4!
£196 for new CAT, centre section and back box. Plus its due its MOT and i have to MOT proof it - change the plates remove the marker lights in the front indicators and refit the side repeaters - which I'm sure I have had to borrow off Ross before!
The CAT fitting kit and all the hangers are included in that price too Andy...
when you suffer turbo lag,but dont have a turbo? :?:
