regret buying a polo
That is the worst batt tray i have seen. Still, it is a common problem, all you had to do was look up under the dash and you would have spotted it. Shouldnt be too bad of a job though, and you know for next time now!
  • Replies 27
  • Views 3.4k
lol that tame mine has a hole in the boot around the bumper mount a hole in the c pillar a huge dent in the door I've just replaced the fuel tank and the head gasket and fully stripped and rebuilt the head to replace the tappets and I'm no were near finding out all the problems yet think of it this way as long the polo has been going there will still be newer cars in worse states of repair and no matter how long it takes to get it nice it will always be reliable
It was registered 2days after I was born haha makes it that more special :p
I've had the following..
-Battery tray 1st welding job I ever did on my car nearly as bad as yours
-Did 3 headgaskets until I found a leak in the original inlet manifold
-When I had the head skimmed on re-fitting the cam my mate over tightened one of the cam caps, needed tig welding!
(I'm still loosing coolant) so new rad and then maybe new head/engine!
-Did a VWII brake conversion which became a saga when they wouldn't bleed involving new brake cylinder and general miss information from various people (know one on here)
-weeping rear wheel brake cylinders, replaced
-fuel pump failed , replaced
-exhaust rusted through and collapsed on the road (always carry cable ties) fitted my own improvised one
-Alternator bearings failed which destroyed battery, replaced outside in the the snow
-oil pressure switch failed ,replaced
-rear wheel bearings are droning, about to do both sides
-serviced spare carb which has ended with both carbs in pieces in my kitchen,I've had no car for a week..
-Rust and tired paint needs seen to before next winter..
-Theres definitely more play in the steering column and rack than before..
Regret buying my Polo, well maybe but it cost £90 and there's not many cars that cost as little as a Mk2 Polo to keep on the road when your as skint as me.
