1.6 AEE engine
Hi, I'm selling a 1.6 aee engine every thing is there exept the cam cover, however i may be able to get 1.
the bottom end internals have all been ballanced up, and it will come with a mk3 flywheel so a perfect engine to put in one of the older polo's, it will also come with the standard flywheel, the engine will require re-assembly as its in peices at the mo as i was going to rebuild with new shells, rings n gaskets etc...
will also require a new cam bearing cap stud, real easy to get dun I'm sure u could buy them from vw.
Will also throw in a box of spares, inlet manifold, tb angine breather n a few spares, there is no wiring or ecu with the engine.
so its perfect to keep as spare or pos swap the internals over, or fix it back up.
looking for £30 concidering the balancing has been done, but open to offers, collection only due to weight
pm me
Alex
  • Views 620
