Kicker SoloBaric S15L7 Woofer And Wiring
Selling this on behalf of a friend: Kicker SoloBaric S15L7 Woofer And Wiring, the sub has been used once to test it and then put in storage as my friend wanted something more powerful and went for Orion HCCA's
Pics:
Cone Side:
Magnet/Coil Side:
Specs:
* 15" square subwoofer. Surface area near equivalent to a standard circular 18" sub.
* titanium deposit cone
* non-resonant aluminum basket
* Rubber Santoprene surround
* dual 4 ohm voice coils for wiring flexibility (with a compatible amp).
* frequency response- 18-100 Hz
* RMS power handling - 1,000 watts RMS (500 watts per coil)
* peak power handling - 2,000 watts
* sensitivity - 88.8 dB SPL
* top-mount depth - 8-1/4"
* sealed box volume - 1.5-6.0 cubic feet
* ported box volume - 3.0-6.0 cubic feet
Available in 8-, 10-, 12-, and 15-inch models, the Solo-Baric L7 still revolves around the breakthrough SoloKon™, the one-piece, injection-molded cone with full-coverage back bracing that pushes more air and creates louder bass than any like-size round subwoofer. It’s good enough that KICKER uses SoloKon across the board as the cornerstone for each subwoofer in the KICKER bass-making family.
SoloKon may be a rock star, but it’s the unshakeable motor structure behind the scenes that propels it to the forefront. Minor tweaks have given the motor an outstanding rep – dual high-temp voice coils, poly-cotton semi-progressive spider, Spiralead™ tinsel-lead technology, highly-efficient UniPlate™ pole-piece/back plate, and a heat-reducing T-cut top plate for enormous power handling. And it’s never been cooler with a new solid pole piece that disperses more heat than ever before, and more venting near the SoloKon back brace and spider landing.
The Sub has been wired down to 2 Ohms and comes with wiring:
Pics of Wiring:
Price: £190 - Drop me a PM if your interested or reply here :thumbsup:
Edited by SoniC6N2
  • Views 295
