mk2 polo coupe s helios blue
Are the interior door cards (and cards in the back) the same on the coupe as they are on the breadvan? If so, how much for the set, delivered?
Thanks!
  • Replies 84
  • Views 4k
Do you have the Thottle pedal and bar, if so can i have pictures, will most likely be correct but I've already been screwed around so want to check
PM me a reply Luke
bump luke pm is on the way tomos mate
bump
Hi mate you taken pictures of the wings yet? I pm'd you my email address
hi mate the passenger wing is shot, but i will get pics of the drivers for you sorry got lost amongst everyone
where in cheshire are you pal, will u take £15 collected for the twin grill?
There pretty much plug and play right, all coupe S came with the loom?
hi mate £20 for th grille and its a deal, i'm near northwich mate ye should plug and play
got a postcode? should be able to come collect Sunday if not earlier.
is everything there including bulbs?
cheers matt.
cheers matt.
erm not too sure if it deffo has bulbs i'll have a look tonight
after the following bits
bonnet hinges - rear
top and lower steering cowling covers
rear boot lifter and clip
battery tray cut out if its in good nick
got the bonnet hindges but not got the battery tray cut out
got a few questions tho, do you mean the steering wheel cowling ? as in from the wheel to the clocks ? and when you say boot lifter you mean the little hydraulic lifter that keeps your bonnet up ? i'm coming manc union this sunday so can bring it then
lifter that keeps the boot lid up dude
and yep the cowling thats from the wheel to the clocks, its only really the bottom one i need, i might have one at my unit, ill check on sunday
deffo need the boot lifter and bonnet hinges tho lad, dankeshun muchly
yep no probs bud i'll bring them up on sunday for you
have you got the rear boot lock, with key? am interested if so :)
Alrite mate do you still have the dizzy off this.. If so how much and do you have a pic so I can make sure it's the right one
Cheers dan
mattpolo5491 - do you still want this grille ?
v-dub dan you have a pm
bootlock is sold i'm afraid darrel
d.watson 08 sorry bud but the wing had rust on it pretty bad :/
dont hold it for me mikey, still interested but I'm try to fix problems on the mk2 atm.
ok no probs
found me a cowling cover in the house,
still got the boot lifter and bonnet hinges.
also after the gearstick, lever and linkage rod that goes underneath the car and attaches to the gearbox
still got the gearbox? was it a 5 speed?
text me your number mate and ill give you a bell and bob up on evening this week or the weekend
07950 675 910
bump
bump
bump - still got...
bonnet
boot
glass (except door glass)
coupe s engines without box's
pooberg carb with k and n
all sorts gonna be going cheap now cos it will be going scrapyard !
bump
bump - still gotloads of bit but off the top of my head...
centre console
red trim clock surround
bonnet
boot
u stil got headlamps
nope sold sorry
