cool cheap mods ?
Painting the horn push surround will look gash dude.
As will painting the heater control surround (unless you paint around the head unit, the ash tray and the area around the headlight switch to match, and even then it's sketchy)
Strip off the rub strips, that's an easy job.
are you f*cking kidding me!?
I've had my bump strips off now for about 2 weeks
and i still haven't 100% gotten off all the sticky stuff left underneath!
  • Replies 36
  • Views 7.4k
Toffee wheel... enough said :-)
without it I wouldn't of got the glue off... EVER!!
took me about two hours with some rag and a bottle of white spirits, but that took some fucking elbow grease :lol:
I used my bank card and some TFR and it took me about 40 minutes on my old mk3 :-) .
didn't it strip the paint aswell??
i dearnt take mine off after peeling one back a few cms. looks a mess..
where did you get the toffee whhel from?
are they easy to use?
if you dont keep your whits about you. You'll burn through the paint in seconds.
Sticky stuff remover is pretty good shizzle
Acetone wipes it off in seconds (nail varnish remover and 3M adhesive cleaner are both basically acetone or you can get it pure from various chemical companies and probably online).
But its as aggressive as 2000 grit wet flat,so you need to be swift and polish/wax the paint after.
2K automotive Thinners is almost as strong in both respects,gives you a bit more time and control. An even safer version is petrol.
£100 of ebay lowerage.
75p for a new cutting disk for the grinder... lowerage :lol:
