mk3 16v injection
john what do you want for the bumper mate? one thing i had contemplated for a little further down the line was maybe smoothing the bumpers and a few other bits and bob's, bad boy bonnet, smoke all the lights, indy's, windows and paint it canary yellow... 90's flex FTW :lol:
and the wheels are 15" mate
£20? I've got 3 15" tyres (maybe 4?) but they're 50 profile which wont be alot of cop.
  • Replies 212
  • Views 33.7k
  • Narrow_Lane
    Narrow_Lane
    Nice :) I'm doing the same conversion (original injection). If you need to know which wires to strip off from the fusebox gimme a shout, I've taken out about 200 wires so far lol
cam don't try and play it down now you perv! lol Been a busy week so far so not been able to do much to it, hoping to get a good run at it over the weekend tho so i'll get the camera out for you mate.
Tony you know they ain't venoms mofo :lol:
jon pm coming your way
lol, only tool on show is a pair of mole grips - i can see how this project is going! :lol:
:lol:
Haha nice one Guy, fair play, looking forward to seeing how this turns out
thanks to a gay exhaust and some stubborn drive shaft bolts i a had really slow start today, luckily for me a had an angle grinder at hand lol, so fast forward a bit and things get moving.
old engine coming out
the only problem i came across today was the drivers side engine mount fouling cam belt cover, a bit of chopping and bending and jobs a good un
i only had the use of the engine hoist for today so i haven't modified the mount yet, i can do that any time now the engine is in with just the use of a jack so that's a job for another day.
i used the mk4 clutch and starter, it seems this was an earlier mk4 with the same size clutch spline thing so fitted straight on it seems.
and dropping the lump in
dug out my air horns that will be going on it while i was pissing about
and a days work done
so that's the easy part done, gonna make a start on the wiring tomorrow :(
Looking very nice 8-)
But how longs the wiring gonna take you ;)
how longs a peace of string? :lol:
twice as long as half a piece of string :)
looking good, is the engine mounts just off the mk3 block?
what are you doing wiring wise?
using the mk4 loom, then mk3 through to dash?
cheers mate, yeah the mk3 mount bolts straight on to the mk3 block but only 2 of the 3 holes on the mount line up. to use the 3rd hole you need to get a thick piece of metal and drill 2 holes in it so you bolt one end up to the engine mount and the other to an unused hole further down the block, i'll be doing this soon so i'll get plent of photos.
as for the wiring i'm going to be running every thing that i can off the mk3 fuse box and then just run the absolute minimum needed to run the engine off the mk4 fuse box with the immobilizer, transponder ect all strapped up under the dash. i was thinking the easiest way would be to splice the power wires for the 2 fuse boxes together so they are piggy backing off each other and both working off the mk3 ignition.
i've spent a bit of time today chopping the mk4 engine loom down and removing the wiring i don't think i will need from the mk3. i'm gonna see if i can get the cut down loom loosely hooked up tomorrow and chuck a battery on and see what happens, if i have any luck with it i can tidy up the loom and start splicing it with the mk3 wiring in the car
this looks good. i will be intersted to see how the wiring goes. as a future rally car of mine my have to be on injection for the rules of the class.
well the wiring is going shit :lol:
it turns over and sparks and if i shoot some easy start down the throttle body she fires up well, but the injectors just don't seem to be doing any thing. more info here click me.
possible immobilizer issue so if any one knows any thing about these please have a gander at the link :-D
is the fuel pump on the car the 16v's
would that make a difference?
its still the spi one atm but i was told that should do the job just to get it running.
This is really doing my head in now, if it was the immob at fauldt it would fire up then cut out so i don't think its that but what else could stop the injectors from priming?
it's now running turns out the fuel pump relay was fucked, should of checked the little things first really but hay hoe at least she's running now :D
videos bitchtits, go go go
this is good news, I'm looking forward into doing mine after summer now
got a small vid i'll upload in a 5, only a shorty tho because it still hasn't got the rad plumbed in and has only a mani for an exhaust ;)
cam it really is very straight forward i'll get you some photo's of the loom and how i'm wiring it in tomorrow, should have it spliced in with the car loom and running off the key by then. it's only gonna need a few of the ignition wires splicing and the red/yellow fuel pump wire running from the ecu to the fuel sender. all the 6n wiring is just plug and play, just needs a few unneeded wires cutting out of the system to tidy it up a bit.
video evidence for you saf old lad, hear her purrr :lol:
Lovely jumble of wiring you have there :lol:
Good stuff though :thumbsup:
winamon =D
thanksamon 8-)
goose, not looking forward to trying to make them wires look tidy tbh, gonna need a lot of black tape :lol:
I know what you mean, had to do the same when I carb'd my mk4, got rid of the ECU and re-did all the wiring. Much prefer simple older cars without ECU's now :lol:
What I did though was to lay all the wires where I wanted them to go in the bay, and then in places, just put a bit of tape around them to hold them in places so it would stay in the same shape and then took it out and wrapped it. Wasn't too difficult just time consuming. Good luck with it though :thumbsup:
Stuff like this Click is good to use instead of just tape, doesn't stick to itself so can easily redo it if you mess up.
Edited by goose
I never use wiring at all. I just use the power of my mind.
i used my gt injection system on my 16valver had the inlet alloy welded there no room under there now lol goes really well
