Bilco's Mk'2 Eaton G Saloon
for those who haven't spotted my sneaky little shot in golf plus magazine :p
  • Replies 1.5k
  • Views 148.1k
  • dubownerbilco
    dubownerbilco
    So another one turned up today.....
  • dubownerbilco
    dubownerbilco
    well today i have picked up a G40 engine. pictures and more details to follow tomorrow, ime so happy its unbelievable!!
  • dubownerbilco
    dubownerbilco
    Well i made a start this morning! First i pulled all the original engine bay loom/fusebox and compared it to the g40 loom so that i could lable everything up for future reference. The eagle eyed
well the dizzy turned up yesterday (would have been quicker but had problems with my bank card...) and it was £45 well spent!
definitively feels much torqueyer (spelling, fuck knows...) all through the rev range and has got rid of flat spots in the middle rev range
H&H ignition solutions = highly recommended!
before and after (notice the missing vac advance)
ahh electric ignition, I'm tempted as my vac advance is now buggered...
the ignition setup is no different to previously, I've just had the advance curve tuned differently to work better with my cams and carbs :)
ohhhh... sorry, misunderstood! well either way, i need to go electric... :p
well i didnt have a single problem getting started through all the snow etc last year and thats without a choke! so yes, change to electric ignition while you can :)
Love it mate. Suits the starmags superbly!
they are currently in the process of being mirror polished :ninja: will look even better soon ;)
Recognised this in Golf+ this month, fair play! Dizzy sounds like a good idea. Was yours knackered, or did you just hear it should make a difference? This makes me want to get on with mine soooooo much!
The fella at bogg brothers suggested it to get the last little bit extra out of the cams :)
Alright dude, just got a quote back from hh and its £105 all in lol, what did you ask for?
thats alot :S
i just asked for the advance curve adjusting and the vac advance mushroom removing, cost me just £45 all in
what happens if you just simply unscrew the vac advance 'mushroom' from the dizzy so theres nothing there? would it affect the engine running at all? as I'm not using vac advance on my afh. isit just a matter of having a hole in your dizzy?
Ah right, i asked for a full restoration and the advance curve matching to my new engine. Did the clean yours at all?
ahh ok, i think they gave it a quick spruce up but nothing major
no they made some triangle shaped plate as there is a small bar under neath that is attached to something inside (crap description, i know nothing about dizzys!)
The UFO shaped thing is a diaphram IIRC , it pulls on a small lever that retards,/advances the ignition timing. I think they will have probably held it static somehow.
thats the one :) described much better!
oh right, just wondering because i simply unscrewdd mine and took it off then put the afh dizzy cover over it, car seems to run the same just wondered if there would be any side affects!
side effects could include: drowziness, vomiting and sever diohrea!
:puke::lol: :lol: :lol: :lol: hahah
What I've done on both my bike carb engines is set the vac advance manually to full. Basically the disc the vac advaned was attached to needs to be pulled all the way round and then secured in position. This puts it in full advanced and also stops it moving around with might happen if you just left it. Also I've just put some duck tape over the whole to stop dirt and stuff getting in.
ah i see cheers! so you just covered the hole then thats cool, just wondered what would happen with it not being there :)
Have you secured the disc the vac advance connected to?
nope literally just took it off!
Lump in the road = fucked sump!
