Bilco's Mk'2 Eaton G Saloon
louvre is already for sale HERE!
  • Replies 1.5k
  • Views 148.2k
  • dubownerbilco
    dubownerbilco
    So another one turned up today.....
  • dubownerbilco
    dubownerbilco
    well today i have picked up a G40 engine. pictures and more details to follow tomorrow, ime so happy its unbelievable!!
  • dubownerbilco
    dubownerbilco
    Well i made a start this morning! First i pulled all the original engine bay loom/fusebox and compared it to the g40 loom so that i could lable everything up for future reference. The eagle eyed
oh shit i see, shame that :(
it was, i made this face :(...
safe in her new home while i finish the engine this week :)
DAY 1 OF REBUILD
disaster!
when popping the pistons back into the block i managed to snap one of my fairly new piston rings!
gsf sorted me out though :) replacement will be here tomorow!
also fitted a pair of new inner cv joints for good measure :)
also removed the bonnet to give better access
and that was it as i cant do anything else until i have the replacement rings :(
not a great 1st day, lets hope tomorow is better!
wheels are back from the painters :)
ohh haaii :unibrow:
Look amazing mate
Need to sort the lips out though, get rid of that kurbing.
ohh haaii :unibrow:
Look amazing mate
How can i do that without making it look lumpy and weird though?
DAY 2 OF REBUILD
went to GSF and picked up the replacement piston rings
went to the bodyshop to collect my wheels (a few posts above)
rebuilt block fully; pistons, oil pump, oil pickup
fully torqued bottom end and refit sump with fresh loctite sealant
fitted and torqued flywheel and clutch
fitted gearbox and ancilleries; alternator, waterpump, timing belt tenisoners and belt (easier to pop the belt into place now than in the bay)
dropped it into the engine bay onto the stiffer mounts, which incidently made it much harder to fit as there was much less room to tug it about into place than with the softer original mounts
day done :)
progress may sound slow, but ime just taking my time and being thorough as i have a while to get it done :)
This thread is both aspirational and inspirational. Some pretty epic stuff in the 30 pages I've waded through today and enjoyed every update.
Dirty alternator and gearbox or am I missing something? Personally if I was having a blingey bay like you I'd have a cc-d or polished gearbox and a polished alty?
Costs too much :)
I have given everything a clean up anyhow, you cant see enough of them anyway
Wow cheers fella!
Glad you have enjoyed it :)
Ime sure there will be lots more to come when the engine is done and i can properly move onto the interior
Yeah, Ben has OCD with polishing and cleaning things :lol:
ohh haaii :unibrow:
Look amazing mate
Depends how bad it is i guess.
Sometimes just sanding it down or whatever can make it look a million times better
I spent £180 getting 3 of my lips fixed up properly though, they re-welded alloy in and then machined them down.
How many of them are damaged?
DAY 3 OF REBUILD
Well yesterday was very productive!
Bolted cv joints to diff
Connected gear linkage
Fitted new clutch cable
Got the head on and torqued down
Replaced camshaft seals
Fully fit timing belt and timed correctly
Helicoiled a thread for the rocker cover
Plumbed in radiator etc
Fitted bike fuel pump and new blue fuel line
Inlet manifold and carbs
Wired in the coil etc
So not a huge amount left to do today to fire her up :)
DAY 4 OF REBUILD
She is alive!!!
A little smokey at first from the oil on the cylinder bores during assembly and she is also slightly tappy but thats getting quiter each time its revd, which incidetly sounds much much faster than before!!
Will have a day of tuning and tinkering tomorow :)
Video of her running: Engine running
DAY 5 OF REBUILD
took her for a little drive around my local area this afternoon inbetween tinkering with the carbs/timing and oh my she feels very fast ;)
top fill radiators are definetly a bastard to bleed! but i got there in the end, i think...
but for some odd reason the tracking seems to be majorly out even though i haven't touched the suspension at all since it last came of the road and was fine :S all i have done is swapped the wheels a few times...
Edited by dubownerbilco
Handrake cable adapters arrived from germany yesterday :)
Rear disc conversion can now be finished as soon as i have time!
Also ordered some carb filters, but better quality ram air foam single bolt on filters :)
New filters :)
wheels painted, polished and put back together :)
cant wait to fit them when the better weather comes :)
Wow, she's wonderfull 8-)
fair play man, she looks good. be nice to see that rear disk conversion on
A very nice car.
I quite like the fact that is half "look at me, bling bling" and half brutal and rugged looking...
If your wanting all out power/performance, i'd sell them individual sock filters, and go back to the single item.
A very nice car.
The one i previously had on doesnt fit these carbs because they are longer so no space for it :( wol see how i get on with these first, there good quality so i shouldnt see them causing a problem
finally got a red trimmed speedo surround!
it might sound daft but i have been after one for so bloody long!
