Bilco's Mk'2 Eaton G Saloon
Swing your cams then ;)
  • Replies 1.5k
  • Views 148.2k
  • dubownerbilco
    dubownerbilco
    So another one turned up today.....
  • dubownerbilco
    dubownerbilco
    well today i have picked up a G40 engine. pictures and more details to follow tomorrow, ime so happy its unbelievable!!
  • dubownerbilco
    dubownerbilco
    Well i made a start this morning! First i pulled all the original engine bay loom/fusebox and compared it to the g40 loom so that i could lable everything up for future reference. The eagle eyed
pardon?
you want me too hang them from the roof and swing on them?
sorry.
Adjust your cam timing
apparantaly these don't like lots of revs, plus unless your cams are lairy as fuck i doubt it's worth revving it to 9k man
I've stupidly hit 9k a long time ago before doing all the lightening and balancing work and it was pulling all the way, and even now at 6500 its pulling like a mother fucker when it bounces off the limiter!
mad man
ride is sweet tho what is the spec on the engine??
cam'd
ported and polished head
750 bike carbs
retuned distributor
lightened and balanced crank
" " con rods
" " flywheel
and a few other bits and bobs
basically everything i can possibly do to still be N/A apart from map-able ignition
sorry.
i didnt think they would be worth it to be fair, what could i possibly gain from adjustable pulleys?
kinda move where the power is a bit sorta thing :)
You using a standard mk2 dizzy?
Saying that your setup is kinda rev enthused. You stil on hyd tappets? 9k may not be a good idea haha
ahh ok then, yeh it is but has been retuned to run a different advance curve and had the vac advance set and blocked off, H&H igniton solutions did the honors :)
Yeah same haha :p
Mappable is the way forward man, it made a huge difference on my mates fiesta haha!
I can't wait for ITBs and mappable ignition !
Glad you're finally happy with it though
Edited by harris.racing
Yeah same haha :p
couldnt be happier mate!
i spent monday afternoon stood on the drive just looking at it thinking what can i do now?!?!
it works perfectly so i had nothing to do haha
uses no oil or coolant, disc conversion works a treat, suspension isnt as perfect as i would like but thats staying as it is until i work out spring rates for custom wound springs!
Haha it's mad aint it, always looking what to do next :)
Have to take me for a spin
yeh quite happily if your ever in leeds?
NEVER haha.
VW action?
NEVER haha.
VW action?
hmm maybe, as i was saying to eric the other day i cant decide which shows to hit!
Action... Harris , when u looking to get you engine in ?
I was hoping for poloshow but realistically I don't think it will happen.
Action is like end of aug?? I'm all over that shit man
so this morning i had the front suspension geometry all proffesionally setup, i paid £65 for the privilege but damn it was worth it, better than paying £15 to the local immigrants put it that way!
turns out i had positive camber on one side and negative on the other, nascar stylee ;)
one major problem was caused by fitting the g lader arb blocks, in that the arb was pushed well over the the passenger side which ruined all the geometry, so after setting that correctly the camber was set bang on to 0 degrees using the bonrath top mounts and then the tracking was set correctly, the car feels so smooth to drive and the steering feels tight (previously wandered at high speed)
also having this done has stopped the top mounts creaking and banging as they must have been under alot of stress!
i had this done by a company called allcar tyres and exhausts, they are an independant company and the lad really knew what he was talking about, put it this way, i live in leeds but traveled to Huddersfield after they were highly recommended by a friend :thumbsup:
Wher'd you get the top mounts mate? I forgot to bid on a set I was watching! So pissed
phil j!
come on man get with the times! haha
Oh so you bought them when he had some :p
Also, out of interest, do you know what your geometry is now set to?
just had them all set to standard settings and its a billion times better :)
dudeee! check this gumtree add! rear window louvre!! get oneeeee!!!
Saw that earlier, so much want for that car...
linkkk!!???
SAMEEE id love a saloon just for that louvre!
