What are people doing on their cars today?
hahah yeah good thread even if it's intentions weren't this :p i would add a propper post but i really can't be arsed too do anything too my car after working on other ppls all week :p
I edited my origonal post so it makes a bit more sense lol
  • Replies 209
  • Views 16.6k
yesterday i went to sort out my suspension, thinking the top mount was knackered and found out the shock was blown, pretty sure the guy said they wern't budget coilovers but no there ta techniks... so getting a new set in the week sometime courtsey off my dad gonna be spending alot of time off the road paying him back with the dole money lol
and greased and used rust penetration stuff on all my bolts to do with the manifold hot some nasty heat wrap around one of the joints so thats probally gonna be a bastard
and genrally noticed alot more chips and minour dents then i ever thought i had
keep spending money on the stupid thing and its not even gonna pass the mot if i can even afford the mot...then theres tax and insurance comming soon :( genraly fucked off with the thing
just fitted LED lights all round, headlights are really really good. They don't project too good but look awesome :)
Did you do the indicators too...i did mine and had the problem of them flashing quickly as if a bulb was out.
Sorted it now though...
Hahaha good man bet you didn't expect this :p
Thought id do my new front shocks today, wouldve got them finished too if VAG had made the slotted nut on the topmounts out of something other than toffee!!!! Tossers!
Wish id done something easy like fit my engine or go out instead.......
today i have:
Driven it,
Put yet another magic tree in my forest collection,
Cleaned new springs ready for the garage to fit on tuesday 60/40 :D,
Sorted out one distorting speaker and ruined the standard dash ones hehe double wattage!! whoops
painted it a few months ago, only just got around to flatting it down a bit (very peely), starting to shine now! just needs another bit of 2000 in places but after doing most of the car in this heat, it got a bit repetitive,
went through on two edges though :@ gonna have to spray them back in when its done
Removed Mk1 Golf rear axel
Drained petrol form tank as Denzel conversion taking place
Sorted Mk3 Golf coilies & found out driveshafts / steering arms rub
Possible chassis notch underway later or wind them back up and do it another day .
managed to pinpoint the source of yer knocking yet fella
No time at the moment,only spent a few hours on it last week. No visible damage to big ends or gudgeon pins/bearings but piston four had heavy melt-scoring and was probably dragging.
I've melted piston four before,its furthest from the water pump and does get warm occasionally,but this wasn't a particularly lean burn. Bit concerned the cooling system is the weakest link here,not sure where this leaves me but for possibly needing an oil cooler.
Anyway,got honer and pistons,not sure whether to change crank bearings too,but no time to do anything at the moment. I'll get back on it in a couple of weeks.
Today i changed the 4x6's (lol) in the boot for some JBL ones (pinched out of my brothers mk2 golf....) changed the rear wheel bearings and sorted out the handbrake, would have changed the top mount on the front, but the top shock nut doesnt want to come off... :(
Edited by dachma'84
Today i spent fixing my mums car. One job was to sort the bonnet release cable thing, had to take most of the front end off the car so i could release the catch to open the bonnet - bastard thing!!
Cleaned it.
Tomorrow, I may clean it some more. Weather/motivation permitting..
gone lower and cleaner :)
Looked at it up on axle stands and shed a tear.
Fecking driveshaft had better turn up tomoz... in which case that is what il be doing.
Then hopefully driving it for a change! :biggrin:
could well be dude, the mk5 polo gti and lupo gti oil coolers are direct bolt on replacements and on on the ports is taken off a now redundant temp sender (youll only be using the black) and one of the rear outlets t pieced off from a header matrix hose. you just need to get the corresponding threaded rod aswell as its longer to take account of it. I'm not sure if it is has a thermostat, or if it always cools
did you hold the centre rod while undoing the nut? otherwise itll never come off, you can use a swan neck spanner and mole grip the top of the rod,otherwise its a 7 or 8mm spanner fitting iirc that always rounds! failing that you can mole grip the shock, dont do it too tight as you dont want to damage it! but tight enough to lock the moles against the arch.
hahaha fucking hate that! big fuck off screwdrivers ormally do the trcik =D
Had one from the BCB 1.6 16v Golf engine,but binned it because it looked useless - hot water heated bit of metal around a one inch oil pipe?
But it seems the 1.6's need it,as its not fitted to an '04 1.4 16v Golf engine i have.
Only other suspect is the larger capacity oil filters I've been using,instead of the tiny ones fitted to the later engines. This one certainly makes no sense to me,but VW have done a fair bit of research and development in their time,so i'll use them again - Didn't have a problem with the small filters before,after all.
Cleaned it.
I stayed true to my word and clay-barred it today 8-)
mikey - i know it doesnt look particularly hamazing, but like you say, if they have spend many man hours in R&D it must be worthwhile!
failing that a mocal thermostatic take off place can be had for circa 30-40 quid and you can fit a remote oil cooler, of which I'm sure youd find something suitable from a scrapyard, rather than forking out 60 odd for a new mocal 13 row. may even help having a couple of small fans on a switch, so that even if the oil cooler isnt cooling quick enough, when the thermostat opens, it should help cool it just that little bit quicker.
I need to sort out the dethreaded oil pressure sender take off on my head, and then i can connect the senders for the guages I've fitted in the car and actually ascertain what the state of play is temp and oil pressure with, with a good blatting.
it could be the 5w40 fully synth is getting too warm and thinning out when under extreme stress, which to be honest, is any back lane, as the engine just wants to be driven hard. i certainly had fun today on my day off work =D
still managed over 40mpg too, not driving shy, 125 miles to 15 quids worth of v power
Taking manifold n components to get welded together then hopefully finding some kind of silicone that will stick my rear wiper blank on!
Just had my annoying knocking noise fixed. (Crappy nuts supplied by FK)
and gave it a good clean.
I shall be finding the slight blow in my exhaust today and proptly getting some weld on it
rest of my paint has finally turned up, so i'll be cracking on with that tonight. might even have a single colour car by the end of the week :lol:
Putting £25 of petrol in its tank :(
Hunting down some paint and sandpaper for my wheel refurb, maybe hammeriting the rear drums too
Edited by dirt_monkey
Considering selling it.....again :lol:
