What are people doing on their cars today?
went underneath the loon to tighten a slipping belt now wishing i hadnt bothered as i need a new headlight, a new cv gaiter, a new belt, a new cambelt, new front shocks, new bushes, and there is a gearbox oil leak between the engine and box
DUBS because there worth it
  • Replies 209
  • Views 16.6k
spent yesterday swapping some wheels onto the lupolo, ragging the peril around country lanes, and did some remedial work on the mk1 cabby in prep for our european road trip.
today i shall be visiting my engine builders to see how my engines getting on, and getting an update on the group buy manis which hopefully should be ready soon as I'm itching to get the lupolo running and on the road
Pulling more useless wiring out of my mk1 golf's engine bay in order to get it running sweetly on these summery days, alongside fitting beetle moon caps to the 5 door mk1, busy but glorious day getting sunburnt :)
Edited by 4speedisallyouneed
I shall be finding the slight blow in my exhaust today and proptly getting some weld on it
Anyone got a mk2 golf/jetta 1.6 front exhaust section for sale? :ninja::lol:
From memory, there's about 3 different sorts, depending whether it's a clamp or bolt on and a single or twin downpipe. Think they're all still available around the £30 mark.
I've mostly been sitting in the sun stripping a free DMTL down and cleaning it up whilst trying to work out whether to put it on the polo or the rocco.
staring at the car through the window as its much cooler in here :)
making doorcards :)
mikey - i know it doesnt look particularly hamazing, but like you say, if they have spend many man hours in R&D it must be worthwhile!
failing that a mocal thermostatic take off place can be had for circa 30-40 quid and you can fit a remote oil cooler, of which I'm sure youd find something suitable from a scrapyard, rather than forking out 60 odd for a new mocal 13 row. may even help having a couple of small fans on a switch, so that even if the oil cooler isnt cooling quick enough, when the thermostat opens, it should help cool it just that little bit quicker.
I need to sort out the dethreaded oil pressure sender take off on my head, and then i can connect the senders for the guages I've fitted in the car and actually ascertain what the state of play is temp and oil pressure with, with a good blatting.
it could be the 5w40 fully synth is getting too warm and thinning out when under extreme stress, which to be honest, is any back lane, as the engine just wants to be driven hard. i certainly had fun today on my day off work =D
still managed over 40mpg too, not driving shy, 125 miles to 15 quids worth of v power
Seems the water cooler's necessary but i dont have air-con and am a good 600kgs lighter. That's my excuse,anyway..
Mocal may work but its a 'scrapheap challenge' motor in spirit, despite its appearance in the gallery, and so that's just cheating!
I'm not sure about the chain-driven oil pump I'm using,tbh. I dont rate its capacity per revolution,and wonder if the simpler 'chase effect' direct drive fitted to all 1.6 16v engines,which looks to shift more oil, has also been chosen for a reason..
And yeah,it was under big stress. I cant test it on most roads,certainly anything single carriageway,because it really is too brutal to stretch on such roads without complete disregard for anyone within the area or probable ability to keep it on the road,but this was hard consistent 'motorway' work with heavy labour in higher gears.
Heat clearly a factor due to melted metal going on,but all under 5.5k rpm. Not sure i can blame that on fresh oil,thin or not? It was only semi,btw. Being a mineral it was 10w at 100oC.
I could just cap how brutal i go with it once rebuilt but that's no fun and i know i can get this engine indestructable - or i might as well drive an Uno Intergrale :lol:
Wish id kept the 1.6 crank with the direct type pump drive now,gonna have fun tracing one of those..
But when i do,that's what i'll be doing.
same here! 90's alarms.. honestly. Managed to get my all my lights working at the same time at last, although in the process I snapped a connector on the radiator thermostat switch as it had corroded away. One more to add to the MOT prep list I guess.
Edited by callum.
Thought about polishing the Golf some more... went outside, realised how hot it was, and decided not to :lol:
yeh I'm not sure if any cars came with a suitable sandwich plate, so looking in a scrapyard would prove fruitless unless you spy a modified motor which isnt pillaged of parts.
the direct drive oil pump is 036 115 105D also B,P and N numbers. same on both polo gti and lupo gti engines I've dismantled.
can be had in many engines which may narrow down the search =] otherwise 90 pounds from the likes of GSF but whether 40-50k used VAG is better than new GSF is highly debatable, with myself in favour of the latter, after previous experiences with water pumps albeit on a mk1 golf gti.
BORA 1.4, 1.6 MODEL 1J2
ENGINE CODE AHW, AKQ, APE, AXP, BCA, ATN, AUS, AZD, BCB
SEPT 1998 - MAY 2005
CADDY 1.4, 1.6 MODEL 2KA, 2KB, 9K9, 9U7
ENGINE CODE BCA, BUD, AEX, AKV, AUA, AEE
NOV 1995 - ONWARDS
GOLF 1.4, 1.6 MODEL 1H1, 1J1, 1K1, 5M1
ENGINE CODES AEX, AEE, AHW, AKQ, APE, AXP, BCA, ATN, AUS, AZD, BCD, BUD,
NOV 1991 - DEC 2008
LUPO 1.0, 1.4, 1.6 MODEL 6E, 6X
ENGINE CODE AER, ALL, AHW, AKQ, APE, AUA, BBY, AFK, AQQ, AUB, ARR, AVY
OCT 1998 - JULY 2005
BEETLE 1.4 MODEL 1C, 9C, 1Y
ENGINE CODE BCA
JAN 1998 - ONWARDS
POLO 1.0, 1.4, 1.6 MODEL 6N1, 6N2, 6V2, 9N1, 9N3
ENGINE CODE AER, ALL, ANX, AEX, AKV, APQ, AFH, AEE, AHS, AJV, AHW, APE, AUA, AFK, AQQ, AUB, ARC, AVY, ALM, BBY, BKY, BBZ, BUD
OCT 1994 - ONWARDS
VENTO 1.4, 1.6 MODEL 1H2
ENGINE CODE APQ, AEE
JAN 1992 - FEB 1999
the crank will be somewhat harder to come across, unless you dismantle an engine.
i may buy into the chain driven afh pump being the failure point, with the 3rd piston from the pumps big end shell melting. will have to see how the gti engines person. my current afh engine is going strong after going on 6k in my ownership, its from a 98 polo, not sure if its chain driven, didnt care to look when i threw it in. but its still alive so ill hedge a bet that its the later type =]
anyway back on topic, I've been dismantling a metering head and packing it, having had to drain it of petrol, otherwise mr courier wont be too happy. and picturing hoard load after another from the unit, and losing the will with fucking ebay turbolister!
I don't know of anythign VAG that has a sandwich plate on, Vauxhalls might be a better source, but I'm not sure if the filter fitments right.
i painted my bready grey over the weekend, just got a few more bits 2 get dun and il post some pics
Today i will finally do something about the broken engine in the car. Cast iron block only needs a hone,but me thinks its time to try an ally one.
Looking to build then fit another bottom end today then,probably using an AUD block from a 6n2 and pistons from a MK5 Golf 1.4. The existing rods from a MK4 Golf 1.6 should still be healthy and the low head-bolt torque should hold the AFH head down well enough. Here's hoping..
i got the headlights, sidelights and washer pump working on the mk1 last night, happy days!
also fitted the bonnet release lever.
cant play with it this weekend tho as I'm away at my folks for my grans birthday. boooooooo!
Finding a splitter for the Pohi. :paranoid:
Mikey - i got my oil cooler for £25 off a MG expert so they're not all major expensive. Its just the sandwich plate that may well be (i used the one i brought from Saf!)
Got back from the scrappy with afew bits n bobs for the G. will be heading outside soon to get it all fitted
Was gona get the melted chocloate bar thatsd under my passenger seat but its to hot to be bothered :)
yuk. i usually have half bottles of warm flat coke under mine!
I dont think i need one - I've found a perished bush in the oil pump and half the water pump fins are smashed. This at a time on a scorcher day when i was caning it..
Got a problem though. The ally block has an M10 thread for the cambelt idler pulley instead of the iron AFH's 8mm. Easy getting a suitable bolt but it wont fit through the pulley. Three engineering workshops have failed to open the hole in the pulley because its too hard - its harder than any drill bit! I cant risk a chemical metal on such an important thread,so i dont know what I'm going to do about that.
When one of my cam cap bolts were over tightened the thread was torn out. There was talk of heli coils but my local engineering firm ended up tig welding the hole, re drilling and tapping. Was like new again.
Could your ally block be tig welded, drilled and tapped to accommodate the smaller bolt for the pully?
Ignore me if I've got the wrong end of the stick lol.
I have done nothing to my car which is frustrating because I have a 3500 essay to write before I can enjoy the three weeks off I have ahead of me :(
i had that problem mate with the lupo and polo gti block
see this thread
http://www.clubpolo.co.uk/forum/index.php?...=179084&hl=
and this post in particular
http://www.clubpolo.co.uk/forum/index.php?...p;#entry1688301
the relay roller
part number 036109244
the guys made me a bar threaded to 10mm at one end to fit into the block and 8mm to fit through the sleeve of the roller, it was impossible to drill through for guys with thousands of pounds worth of machinery so dont bother trying it at home, I'm glad i didnt bother!
I've considered those options guys,I'm gonna chase up for helicoils tomoz because i think it'll be strongest with the hardened helicoils plus tensile M8 than any other way. If i have no luck in the morning search then i'll simply tap an M8 thread next to the M10 one.
Front wheel bearings for me today!
Well after fitting my new manifold an sorting it all out so the exhaust fits properly with no rattles or bits hanging too low normal driving has thrown the added dilema of bottoming out on it especially now it's spaced out up front, do work permitting I am winding te front up a touch.... Yes.... winding it up! I'm just glad I didn't post this on edition otherwise Id get banned for satin things like that haha!
