9n3 Rear Adjuster Removal
When you remove the adjuster plate from the rear spring do you just pull the whole adjuster and plate out and sit it back in like a standard spring? I tryed it the other day and it seemed like the spring was too big to fit properly around the lip? :?
cheers in advance
  • Views 939
