Brake grease vs 'high temp' grease ?
I didn't have any proper brake grease to use when fitting new rear shoes, so I used what I had - it says it's 'Lithium based' and has a 'high melting point', and I only used a smidgin on the ends of the pistons where they contact the shoes and on the bottom pivot point. I'm wondering if this is not a good idea and maybe I should pop the drum off, clean it up and use proper 'brake grease'.
What do you think ? - or should I just save myself the money and just clean up what's on there and not bother with anything ?
Edit: Scrub that - having just googled the price of the proper stuff, I'll get some tomorrow and use that. I can't see a way to delete this post, so - apologies !
Edited by aneng
  • Views 470
