Harryt's mk3
think stock ones are ok for ra's. but correct me if I'm wrong
  • Replies 73
  • Views 9.6k
gentle man above said someting about needing longet bolts thats all
My 13" 6J wide BBS ra's needed longer bolts.
You may think there long enough but there not. The bolt tread wont go far enough in the hub, making low tourqe on the hub.
Usually you will thread the bolt and your hub threads. Best getting longer ones pal :thumbsup:
This was on 13" inch ra's though so the et may have been different.
Edited by mattpolo5491
ok cheers,
yeah mine are 14's with an ET of 20
where abouts can i get these magical longer bolts???
ok so no wheels today, got as far as ordering bolts for a mk2 golf as thats what the wheels were (i think)
also going for 185.55.14 tyres as they're 37.99 +vat each
the 195.45.14 are at 59.99 +vat each (bugger that)
friday i hope
pics to follow
The G40 13in BBS RAs and late Mk2 Golf 16V ones fit with standard bolts.
If you get the 14s, as fitted to some 8V Mk2 Golfs, you will need considerably longer bolts. I can't remember how much longer though. I think they're either 19 or 24mm, but you'll need to check. For some reason the 14s have a thicker hub mounting face than the others, even though they're all about the same offset.
Edited by Alex
I've got 14" RAs on my loon. need much longer bolts with the tapered seat. Put your bolts through them and see how far they reach and then measure them and you'll know how much longer they need to be.
d
have got some longer bolts off a mk2 8v on order for tomorrow. 16 locking ones for 40 quid????
tyres tomorrow or friday depending on times then its weekend shots all over!!!!!!!!!!!!
got the aforementioned bolts but they're still too short so ordered more...
but here's a teaser
should be all on and riding dirty on tuesday!!!! yayayayaya
tuesday's just around the corner
oh dear oh dear oh dear, major scrubbing.
Had to cut a section of the arch lining out. and remove a screw and it still rubs
arch rolling???
any idea on prices, i know you can do it yourself but i'm lazy as sin.
try them mate www.archenemy.co.uk
Edited by mattbirkin
looks good, but a tad pricey
the bloke at the garage said he did his himself, with mole grips and then just fillered and resprayed.........
Part worns are always a good shout to. Usually hard to find four the same brand but if you can get pairs then its not to bad.
part worns are shit! do not buy them guys! i bought some from top gear tyres in ellesmere port they were dunlop sp3000's after two weeks one split across the whole tread of the tyre, took it to a garage hoping to get a refund at it turned out the tyres were from 2000! seriously guys its a no no I've found a place that does A539's for £65 fitted and balanced with a vavle each!
agreed. part worns are a waste of time and most of the time dangerous. spend a bit more and get a tyre that lasts a LOT longer. and I've found that budgets were lasting me 2months tops. switched to falken ziex 912s and 3-4months down the line and I've still got atleast 7mm of tread all round :)
new wheels declared on insurance, £36.something
so total cost for everything
£140 - wheels
£ 40 - Bolts
£170 - Tyres
£36 - insurance
________
£386 all in
________
who agrees thats all a bit much????
arch rolling???
why didnt you just buy the right size tyres in the first place? it would have saved you money in the long run and save you from having to mess with the arches
i bought the tires at the highest of my budget, the 195/45/14's as recommended were far too much 59.99 a corner
the ones i've got now are the lowest profile the garage could supply
also got a free backbox, pretty chavvy as the pipe is about 4inch but hey... i'm different....
i'll get some pics when i'm back home
next time you buy tyres give mytyres.com a try. most garages will fit tyres for a bit of cash.
sounds cool,
thanks
Yea my tyres are normally pretty cheap for tyres, you got any pics with the wheels on the car then? :)
it's always too dark, i'll get some phone ones after work tomorrow
probably getting the arches rolled early next month
washed and waxed car today after work and took some shoddy photos before it got dark
they're from my phone, dont expect any better as i dont have a digital camera (POOR)
bought one of these today :)
quick question. if i have the filter here do i still need the one in the air box????
cheers
no. you will be making the air flow restricted leaving the stock filter in :)
