So...Whos got the lowest Mk1,2,3 Polo on here?
Yeah he would Toby... Or would he? :paranoid:
Would be interesting to see how your air fairs against my old hydros in terms of drop, although thinking about it you have those adjusters to play with too
Edited by Mclovin
  • Replies 326
  • Views 48.6k
  • They weren't that bad haha Pre dropping front Stolen from new owner think he's raised it
  • I THOUGHT I MIGHT MENTION I DON'T GIVE A SHIT WHAT YOU PUT PRIOR AND CAN ALSO TYPE IN CAPITALS Just because you put about it being changed doesnt mean I'm not allowed to put a comment about it, i wa
Just remove them for purpose of lows :ninja:
actually- seeing as both our suspension is based on my design- it would be the same wont it. i can just run mine lower as i could raise it up to drive it!
I had my car on space savers once while i rebolted my wheels and it was so low it couldnt get in the garage as the floor hit the sump plug on the edge of the concrete where the garage door sits.
Ben - take your springs out and see how it goes then- thats where I'm at (I'm running a bumpstop about 1cm tall)
oh and your sill will always look high as mk1-3 all do - unless you get some nice side skirts like mine:-P
adjuster ring?
do you mean the spring nut/plinth? - i dont have these do i lol i have air instead of springs - and the bag is 4inch long at its lowest (deflated) iirc the lowest your spring will sit loaded is 6" i sit on the bumpstop when its lowered - its only a 1cm bumpstop as i didnt want the wheels to hit the arches.
il see how close it is over the weekend - I'm about to write up the next mod I've done on the car - all will see why I'm removing all the wheels and stuff
Edited by KiZ
yer i have a adjustment ring that i made to build the bag bracket - but my bag height is 4" deflated - so i can run it till the bump stop hits the custom top mount and its on its lowest possible setting without having the adjustment rings so low. if you had shorter springs then you wouldnt need to run them that low.
to get mine any lower id need to chop the top of the turret, and the dreaded notch - which after what i discovered in january will NEVER happen on one of my cars
My Idea.... ;)
Not as such, common sense would see it as an option lol
Different one....... :)
Nothing New Mind...
what idea? to fit shorter springs- are you being serious?
shorter, stiffer springs lower cars- what a shock- you are a genius
:lol: ahahahah ^^
Never Assume anything........ Brolo
Get shorter struts.... chop housing to match...
Then.................
you get me breda?
thats whats already going on, Gaz do that- its getting the dampers which is the issue. in running what me, ben, toby and guy are- the strut is already shorter than the polo strut housing- that was part of me going down the route weve all done.
and if you limit yourself by lowering the strut anymore you are stuck between -100 and below!
Just putting it out there....... i have one of the most simplest suspension setups ever created :lol:
Worth a try if you've got the skrilla? ..... Big Companys do custom struts? Koni, Blisten?
And by chopping the housing you will loose adjustability.. (Not that ben cares about that :p) Is a Negative.. No point in having the thread there..
Only other thing is to turn down spring cap 5mm... worth a go..
Was just thinking 'is it even worth it?'
Then i thought, oh god.. dont give ben this idea :lol: As 5mm is 100% worth ripping it all apart for ben :lol:
Remove strut and replace it with an appropriate length of wood carved to suit, problem solved
care to enlightern us?? :?
i removed a piece of metal behind the turret to fit a panel in- upon removing it i could move the whole chassis leg up and down about 2" see my thread- its in there the bit i removed- sparked off a little debate as i welded in a reinforcing brace, then burt posted up a photo of VW themselves bracing this area on a race car.
i dont believe the chassis is strong enough to cope with having the metal removed and a new section put in without bracing it along the bottom- which defeats the object of doing it in the first place
Page 18
http://www.clubpolo.co.uk/forum/index.php?...3524&st=425
Agree with kiz, of your gonna notch it then it needs some fairly substantial bracing put in to give it some strength back
you on about driveshaft notches? i haven't read up on notches, so you cant just literally cut a small square out?
Yeah, and yes you can but expect the chassis legs to start giving way in the not too distant future :lol:
oh shit lol, how have you stopped that?
Page 18
ah i see, thanks for the heads up bro
not the lowest, but still pretty repectable for back in 2006 lol
