ENGINE TAPPING NOISE!
Mine is only an 8v but i had a similar noise coming from mine, and it faded when the revs rose. Eventually figured out it was a worn distributor so changed the whole lot and it was fine after that!! Just an idea! :)
  • Replies 25
  • Views 55k
  • Hi, just some advice. The 6n2 engines are known to sound like that and be completely normal. It seems to be a peculiar characteristic of those engines. I suspect you may be comparing the AFH engine wi
