Gear linkage
Hi there is the gear linkage a rod type, if so how much for the rod, it will have to have the plastic knuckle joint (gearbox end) in ace condition, you might want to unscrew the point where it is attached to the gearbox to save from breaking it. Cheers Pete
  • Views 369
