20mm wide Stub Axle Spacers
As title. Use these to space your rear wheels out 20mm without the need for wheel spacers which put more load on your bearings. Had these fitted to my mk1 golf for about a year now, and just replaced them with 12mm ones so these are for sale.
Will fit all earlyish VWs with rear drum brakes, Ie Mk1-3 golfs and polos and possibly other models such as 6n polo. If your car has the four bolt stub axles then these will fit. :-)
Made from mild steel. You will need longer bolts to fit these, and I can supply them at extra cost if required.
But I'm asking £20 plus postage for the spacers
Located in Stockport
Arun
  • Views 175
