Polo G40 killer :O
Yep, Phil's is a RHD Jade Green mk2 coupe with the old skool Audi 3.6 V8 in the back.
its blue! and has 4.2 wrote on the rocker cover - so no it aint!
nick wasn't saying it was phil's, he was saying why it wasn't phil's :lol:
  • Replies 81
  • Views 9.5k
oh yer - DOH....my bad
please accept my humble apoligies for being an arse
best I've seen still gota be this mk3 polo vr6 turbo
someone posted it on here a while ago :)
yeah me lol it was the topic starting car :D
Edited by VW+SWFC=:)
It's a shame people aren't more into lap times than quarter mile times..
When I was on the Starlet / Glanza Club there were dozens of track days and lap times etc..
Thats a good point smithy... Lap times incorporate more things like the drivers skill and the suspension/brakes of the car!
Set it up! Il bring my 1.3 8v badboy down to the track and spin some wheels :p show you how its done haha
I think it's been looked into before and the money / interest just wasn't there..
But I don't see why shows can't push the idea more.. I remember at Inters last year they had a small track set out and I much preferred watching people pushing their handling to the limit around that than driving in a straight line..
I mean I'm not knocking them, 10 second quarter miles in old VW's are crazy! But people spend like £600 on coilovers and such and never seem to put them to the test..
I have no aspiration for a quarter mile run,but laps appeal.
anybody have hurt of this polo? it,s 380hbp and 487,8 nm
http://www.polotreff.de/data/forum_upload.php?IID=126983
Yeah, was 250bhp a few years ago though? Hell of a jump to 370bhp! Although it's been stroked and bored since then?
found this on polotreff! It,s a big list.
· Umgerüstet auf einen Garrett GT2860RS Turbolader
· Lancer Evo 8 Ladeluftkühler mit umgeschweißter Strömungsgünstiger Anschlussleitung
· 440er Einspritzventile
· 60 mm Ladeluftleitung aus Aluminium
· Drosselklappe elektronisch Audi RS6
· Kurze Ansaugbrücke mit Strömungsbank gemessenen Trichter in inneren Sorg Motorsport ( Sonderanfertigung)
· asymmetrische Nockenwelle mit umschliff auf Tasselstößel
· angefertigte Tasselstößel Drehzahlfest bis 11800U/min
· verstellbares Nockenwellenrad
· Zylinderkopf Ein/Auslas aufgeweitet auf Dichtungsgröße und poliert
· Verstärkte Ventilfedern und Titanventilteller
· Ein/Auslassventile Bearbeitet und poliert (größere Auslassventile Natriumgefüllt 31,4mm) (größere Einlassventile 33mm)
· Ventilsitz Strömungsgünstig bearbeitet
· Angefertigte Schmiede-Turbokolben mit reduzierter Verdichtung, stärkeren Feuersteg, 20mm Kolbenbolzen, Kolbenboden und Kolbenschaft extra beschichtet
· Verstärkte Pleuellager oben
· Verstärkte Ölpumpe (ca. 30% mehr Druck)
· Ölspritzdüsen für Kolbenbodenkühlung
· Kurbelwelle um 30% erleichtert, ausgewinkelt, feingewuchtet und nitriert
Versteifungsplatte für Kurbelwellenlagerböcke gegen seitlichen verzug
sowie Ölhobel mit Schwabbelblech
· H-F1 Hochleistungspleuel in polierter Ausführung, gekürzt statt 144mm nur noch 135mm Länge(dadurch Drehfreutiger) mit einer Zugfestigkeit von 1400n/mm und einen Pleuelauge von 20mm Durchmesser (Sonderanfertigung)
· Tilton Schwungscheibe 180mm
· Tilton Sintermetallkupplung mit Alu-Anpressplatte 550N/mm Drehmomentfest.
· Marke Eigenbau Auspuff (Durchmesser 76mm)
· 76mm Hosenrohr Marke Eigenbau
· Edelstahl Stoßaufladungskrümmer aus 1.4828 Material Marke Eigenbau
· HJS WRC 100 Zeller Kat (Durchmesser 70mm*130mm*360mm)
· Bosch Rennsportsteuergerät (bekannt aus den Formel 3 Bereich (besser als Weber Alfa da es zu träge mit der Ladedruckregelung ist.) Motorelektronik mit Sonderausgänge, mit Aktivierung von 2.Kennfeld, mit MAP Sensor bis 3bar, OT-Sensor,Nockenwellensensor, Potentiometer und Programmierbarer statische Zündung
· G60-Getriebe passend umgeschweißt und umgefräst, auf verstärkte Lager umgebaut. 1, 2, 3, 4 Gang länger übersetzt, Differenzialsperre von Drechsler 100% selbstsperrend je nach Traktion
getriebeübersetzung:
die letzte hat die übersetzung:
gang1: 3.30:1
gang2: 2.08:1
gang3: 1.308:1
gang4: 1.02:1
gang5: 0.83:1
achse 3,389
das projekt startete vor ca. 8 jahren und wurde immer wieder verbessert,
I reckon a Club Polo trackday is in order! Don't need too many if we book on a trackday that has already been set up...
Agreed!
I could look into sorting it for early next year before we go to the ring.
Yeh, I'd love to go along to the 'ring but it's such a massive cost to cover, maybe in 2012!
Somewhere shorter, and central would be best, somewhere like Silverstone, Thruxton, or Bruntingthorpe is too big for a few Polo's! Want somewhere smaller and more technical.
2012 sounds good to me.ill have me other engine in and other bits sorted by then and if i aint I'm going to sack meself lol
Theres a 1000bhp mk1 mentioned on the mk1 forums somewhere. It's not road legal though. Running a faster 0-60 than a veyron.
Found it.
1047 BHP Mk1 Polo.......... :blink:
The guys from AME Racing did the Polo MK I and lift it to Bugatti Veyron perfromance
basic vehicle: VW Polo MkI
engine: VW 1.8l 16V (Turbo by AME)
power: 1047PS/770kW 950Nm at 7734rpm with 2.75bar boost
820PS at 2.1bar boost
1/4mile test so far driven with 2.1bar boost and 820hp 9.42s/245km/h
acceleration perfromance with 2.1bar boost
0-100km/h (62mph) 2.7s
0-200km/h (125mph) 7.0s
0-245km/h (153mph) 9.42s
shift rpm 9400rpm
topspeed 6.gear at 9000rpm over 300km/h
6speed tranny from Audi TT with quattro AWD and AWD lock
8 fuel injectors 650ccm at 3bar
adjustable fuel pressure up to 4.2bar
Garret GT 40 RS Turbo
exhust mainfold with push charge (dont know the correct word for Stoßaufladung)
AME High performance piston roads with improved connections 160mm
AME forged pistons 82.5mm
crankshaft 86.4mm lift
alu oil sump
improved cyl head with stronger valve springs and fixed overhead bucket tappet
different camshafts for intake and exhust valves
special build intake mainfold
alu 4 stage air intake system simmilar to Rally sport used or the one that Audi used in the US IMSA race series
free programmable CPU with AME Motronik 2.65
exhust system handbuild 76mm
intercooler water air
water methanol injection
clutch Sachs RS2 Sinta flywheel from VW G60
coiloverkit suspension
street tires 16" with 205/55 tires
race tires 15" rims with AVON slicks
etc.
weight including driver under 900kg(1980lbs)
Link for the Vids...
http://images.google.co.uk/imgres?imgurl=h...%3Doff%26sa%3DN
Edited by asherz
theres well known mk3 with a 20vt in the boot on nitrous doing 10 second 1/4 miles
I think the well known 1.3 8v front drive Mk3 running 12s is more impressive though!
I disagree
When your in times between 10seconds and 12seconds the gap between 10 and 12 is massive!
Indeed. Though I think Toby's point was more that 1.3 8v FWD and 12s is impressive given that it's not exactly a good starting point for a quick quarter. There are plenty of road legal 10 second (and quicker) RWD cars with massive V8s knocking around - whereas there are only a couple of FWD cars in the 10s that I know of in the UK.
That MK1 needs some 7x13 ATS Classics if ever a MK1 did..
I agree, I have no interest in driving in a straight line.
I could set a track day up if needs be.. Perhaps Spring next year?
I'd be interested if something was organised mark
Track Day VAG only @ Brands Hatch
Brands Hatch Weds November 24th
Come & join us, I have set up a group for our Beetle Challenge drivers http://www.beetlechallenge.com/ to book through so we get a discount.
If you want to book a place via Beetle Challenge group you must contact them on 0870 850 5014.
The discount will be applied once we have 10 or more drivers.
The pre discount cost is £149.00 per vehicle. Discount price £134.10. once 10 or more are confirmed.
(You don’t need to be in an Air-cooled to book via the group as long as it is VAG your in)
Details…….
The day co-insides with the PREPT meet (large monthly VW/German meet)
It will be open to all closed wheel VAG vehicles.
All drivers will attend the morning briefing where the chief instructor will explain how the day will operate and rules and regulations.
All vehicles must also be under the 105db noise limit.
As long as the vehicle is in a road worthy condition and under the noise limit it can take part. Racecars are allowed, you do not need a roll cage, fire extinguisher etc.
Helmets must be worn at all times (motorcycle helmets are permitted) or you can hire one for (£10).
Passengers are allowed (£10) but must be over the age of 14 years.
You can share a car. You can sign additional drivers on for £25. Once you are signed on as a driver you can drive any vehicle (obviously only with the owner’s permission!)
Open pit lane format so drivers can go on and off circuit as much as they like within the six hours of track time. All the rules and regulations will be explained in the drivers briefing. There will be full marshal’s, medic, fire, race control personnel team and instructors, with driving standards being monitored at all times. Anyone they think needs a bit of help or is getting out of shape is brought into the pit lane for a chat to reduce the risk of incidents.
For event details they visit www.clubmsv.com/vag
