Fitting a different cam to your 8v engine. (GT cam covered)
Nope, its only 030 af I'm afraid.
I'll have a look on etka on the pc later to see what you've got.
  • Replies 100
  • Views 46.1k
  • No the GT dizzy woundnt be compaitble with your AAU mate, It a pretty much bespoke item to the GT.
  • Guest pologirl90
    Guest pologirl90
    I haven't looked at my rocker cover recently, will have to check. Am I fit? Well my brothers mates all say so, so I guess.
According to this link
http://etka.auto2.ru/epc/cat/vw/PO/1992/120/49/1251697/
You've got a camshaft from an AAU, which I think is a 1.05 litre engine out of a mk2f if I'm not mistaken. Sorry to be the bearer of bad news.
So today I found a cam in an injected 1.3L Golf II, but I can't seem to identify the part number. It actually has 3f as the last of the part number. I can't remember the rest of the number. I would venture to say 030, but the 3f part threw me off. Can anyone identify this part number or know if it's a decent cam?
Edited by ca180
  • 5 months later...
I just read this through, and it's definitely not 60NM of torque required for the bearing caps, (in english) its more like 10 lb/ft. I will have a look at the haynes later and confirm.
  • 3 months later...
Dont know if I've missed it but will i need a vernier pulley on a 1.3 spi engine out my 1995 polo 6n?
  • 5 months later...
Indeed, my sausage fingers hit both keys (6 & 5), supposed to be 6NM
My bad.
They're 6nm + 90 degrees
Depending on what engine!!
Haynes says 7NM for 3F
Oh right, 6n is +90 but doesn't say replace stud :s
Has anyone fitted a gt cam to a 6n yet?
Nope youll be the first person of all time to do that! Lol
Yes it's been done - on a standard pulley too. Just don't time it to standard marks
Thats the hag tho trying to find one and also trying to time it up.correctly. But it would be cheaper than paying 320 for an uprated cam for the 6n
definatly on the cards atm :|
You can use the mk3 cams. Around £180 new. Even use the 6n pulley, just time it 3 or 4 teeth off the standard marks
  • 5 months later...
Hi Guys,
When swapping Mk2F cams (e.g. a GT cam into AAV or AAU), has anyone ever come up with emissions trouble at the next MOT (assuming you've reset your timing OK)? I just wondered if the existing ECU is happy handling the new setup, or whether it ends up with dirtier emissions? Lambda should keep the mixture OK in any case???
Also, I have a spare AAV head knocking around which I may fit to my AAU if ever I get a problem with its head. The AAV head has bigger valves on the intake. With AAV head/cam/valves would you expect any difficulties, or even a smidgeon of extra performance!? +1 BHP maybe? :lol:
Cheers,
Bread
So how do I get a new seal on the cam without taking the pulley off :retard:
You can't. You don't have to take the cam out but you do have to take the pulley off.
  • 3 months later...
Lmfao !!! Just read how to change my cam and had to keep reading, fitting cam for payment in kind. Legend ! Haha
  • 4 months later...
so a gt cam wont go on a 1043 aev lump then? :doubt:
  • 4 months later...
I've fitted a gt cam and head to my AAV and had it running 10/15 mins and it is tapping like hel!!! any advice?!
Did you put new tappets in/ soak em in oil etc before putting it in? Correctly torqued the cam bridges?
Dont usually need new tappets unless they for some reason are mega worn!
Take them apart and clean them out then fill with oil
  • 6 months later...
brillant thread, i have a hk engine, so will need to change the whole head, I've got one from a g-reg mk2 i scrapped, will the pullies be the same number of teath?
does anybody know which 1.3 or 1.4 engine had the biggest valves, cos if I'm changing the head might as well go for the biggest valve optionj,
will the 1.6 have bigger valves or is that pointless cos the 1.6 is a strocked engine any way.
I've also got a 1.4i golf engine from a j reg golf, I've used the electonic dizzy of this on the g-reg polo 1.3 before a parted it out.
which cam other than the gt is best to go for...........newman, kent.....etc any advice would be great before i spend my money.............cheers
  • 3 months later...
If you're a idiot like me, and didn't set the timing before having it all off, does the alternator have to be loosened and auxiliary belt and wheel off to view the crank timing? I've had the head off and just trying to rectify my mistakes... Cheers
No, there should be a pointer (either plastic or metal depending on early/late spec) on the lower timing cover which will line up with a mark on the alternator pulley when you set the bottom end to TDC.
