sidestrips and carpet help?
hi
i was wondering how you remove the sidestrips in a 6n?? i don't know if sidestrips is the right word
but i mean the grey plastic edging between the carpet and the black rubber door seals? :?:
I lifted part of it up to look under, and i can see some sort of clips that the carpet hooks onto?
can i just pull these sidestrips out and then reclip them after??? i need to run some cables to the rear
and this would make it much easier as existing wiring is already running under the carpet :-)
thanks in advance for any help
eddymcbrambram
  • Views 614
