Mk2 4wd 16vt Bready
Were do you work Kev13?
building chemical tankers for last 11 years before that 5 years building/ restoring classic and vintage cars body work mainly doing
i am 6G code aswell mig and tig so do no abit about welding
as said am not having a dig am just pointing something out
Edited by kev13
  • Replies 1k
  • Views 110k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
Woa man I was only asking as I work for Esterline at Stockton that's all.
And to be honest for the sake of it you may well be in good faith but looking at the scale of this build what possible benefit could questioning the strength of the weld when all you can see is distant photo's.
we both know a mig weld does not have to be pretty to be strong and with all the plate going in it will tie in just nicely.
but that dont matter how much plate is put in if there is a lot of penetration problems
Were did you say you worked Kev13???
Oh and as your 6G coded so all you can do is perform a Grove weld in a fixed pipe at 45%??
Is that it?
Coding just means that you have sat the training and follow the WPS and propa welders don't quote what coding they have unless they are in an interview and Pete's build thread is not an interview.
Edited by Mk2 olop
This page must be the hardest page on this thread with 3 northerners posting in it... 2 of them brewing for an internet fight n'all! :D
Whos the third northerner matty youve lost me lol
will hopefully have a massive update next week as laptop should be fixed at the weekend finally
Loads of progress has been made and lots of new parts bought
Matty is from Guisborough which is near Middlesbrough Norf east innit........
Looking forward to the updates Pete!
You don't have any cam pully bolts kicking about do you mate?
ATTENTION REQUIRED: URGENT UPDATE IMMINENT, IF NOT COMPLETED DURING NEXT VISIT ALL WILL FAIL AND YOU SUCK!
Still no laptop hopefully picking it up all fixed from my parents house this Sunday
So maybe an update next week or you can just go on my Instagram ;)
Which is............
stinkypetebmx
right best do a bit of an update no pictures though unfortunately as still no laptop :-(
the rear end isnt fully adjusted yet and it only just fits in the garage will upload some pics to instagram this week/weekend as have friday off for working on it.
anyway i thought i would do an engine spec so people can see what work has gone into the motor alone so here goes:
BCB block machined to run oil squirters and sump bolt holes re drilled on one side to match steel sump not standard ally for this block.
back of the block has had casting removed for clearance on driveshaft and transfer box.
top of block has been skimmed to clean face and raise C.R. a little
lightened, knife edged and balanced AFH chain drive crank machined at one end for drive pegs for chain conversion.
Forged 1.8 20vt conrods machined to reduce thickness from 25mm to 20mm and the little end rebushed from 20mm to 17mm
Forged 1.6 gti polo pistons low comp should make the engine around 8:1 C.R. with the decking and head skim
Head is mildly ported and skimmed and fully rebuilt
Full Cam chain conversion with Vernier Sprockets and hydraulic tensioner.
Full dry sump setup currently being made running a 3 stage Weaver brothers dry sump pump
Fuel lines are full stainless braided teflon with AN6 fittings
CBR 1100 Individual Throttle Bodies with custom billet ally machined manifold
custom ITB inlet plenum
2.5" boost hoses and front mount intercooler
Billet ally fuel rail
5 bar 044 fuel pump running from ally tank in boot and custom swirl pot.
water meth injection setup
550cc injectors
BV50 VG Turbo should easily run upto 2 bar of boost
38mm external wastegate
g60 lightened and balanced flywheel with VR6 Carbon Kevlar clutch
02M Audi TT Quattro Gearbox
custom turbo manifold
3" stainless downpipe into 2.5" main system
Omex 600 ECU with additional extras
Custom alloy rear water pipe
Custom alloy thermostat housing
Custom alloy rear breather setup linked into dry sump system
Full alloy radiator pipes
fully alloy Radiator with modified inlet / outlet pipes placement
thermostatic sandwich plate with oil cooler setup
Billet 30 micron free flow oil filter with remote filter setup
and more will update as i remember later
Edited by StinkyPete
  • 3 months later...
any news or updates on this pete ?? hows it hangin lol :-)
loads done since the last update just too lazy to spend hours loading pictures to update on here and broke my iphone so waiting on that getting fixed.
I do upload pics onto my instagram everytime i work on the car though and progress will slow now as just bought a house and it needs ALOT of work.
Other than that not too far off paint stage then final build up.
Gets some pics up, sadly i cant get an instagram account as i dont own a baseball cap or skinny jeans
Any updated photos Pete? I've been following this thread for years now :) Cant wait to see the finished product!
And me. Please don't say it's died a death. Need to see this finished
Don't worry not dead definitely still going. Just on hold while I sort my new house and build the garage for it. But loads done since last proper update. Just don't use a computer much anymore so I don't really upload pics or update but will try get around to it soon maybe this weekend.
Believe me it will get finished although looking at it I probably have a 6 months to a years worth of work left to go into it to get it how I want plus it needs a lot more parts. Which is money I don't have ATM while renovating the house.
Glad people want to see it done as much as I do
Come on pete, final push!
Yeah it is in the final stages I would say as shell is near completion mainly few mods left and then paint. Then final build up for testing.
House comes first ATM tho as have half a bathroom and half a kitchen done so need these finished and garage built to get all my tools and machines out the house
I recognise that story my man, sounds all too familiar. Hopefully my garage goes up this spring.
Keep it up
  • 6 months later...
Cant wait for some pics Pete to see whats its like now.
id check his instagram he dosent come on here much anymore
Whats his insta?
