Mk2 4wd 16vt Bready
the adjustment is 15 degrees either way most standard verniers do 12 degree either way so this gives a little extra adjustment which i will need for mine when i do it as i will have a decomp plate to adjust for as well :)
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
Suits me too, looks extreme, exactly as requested :-p
Plus, hasent fallen apart yet, which can only be a good thing ;) hahah!
well rear floor finally cut out just needs neatening up
and thinking today i decided to bunk off the single TB and will use my ITB's for MOARRRRR POWERRRR and they match up near enough perfect with the manifold base plate I'm using :D
so it will be a turbo on throttle bodies engine build now
anyone know if i can run the 6 psi pressure switch in the plenum before the ITB's or will it have to be after the the throttle plates
plus using the ITB's sorts out the plenum design as it doesnt really matter where the boost runs into the plenum as such :)
So this week i neatened up the hole in the rear floor and cleaned up the areas I'm going to weld the cross braces for the shell and rear diff
then tonight i sorted out the cross braces getting to the right length to fit properly and welded them in :)
then put the rear diff underneath in the right sort of places just need to raise it into place and hold it there somehow to weld the mounts to the brace bars
whilst doing all this I've been sorting my turbo exhaust housing at work have chopped alot of excess off and cleaned it up
the crack in the wastegate exit
other crack in housing these will all be sorted properly :)
my modding for the exhaust housing
this 90 degree bend will have a v band clamp the the downpipe end once i make the v band bit out of mild steel it will take it for the 45mm i/d tube to the 2.5 inch v band clamp
i have bought a full stainless V band clamp from ebay for £10 posted :) i will use the clamp and one stainless V band side for the downpipe and as said above I'm replacing the other side stainless v band bit with the mild steel one thats getting welded to the exhaust housing
I'm using a V Band as they are alot easier to whipe on and off and are supposeldy alot better seal so il see
also bought a nice adjustable pressure regulator for the standard afh fuel rail can be adjusted from 3 to 5 bar so will do nicely to replace the standard 3 bar one and can be raised if the turbo needs more fuel pressure won it brand new for £9.99 posted :) bargain
also this made me laugh alot the other day and is like my car tbh
enjoy
I Enjoyed. now please update with piczorz of updates.
I have in the post above that you pleb lol
Are you gonna be doing any triangulating of the braces in the back?
:lol: Thats not an update, thats a shiney valve! we can all post pictures of shiney valves! :-p
Ben what about the floor cross brace pictures and the turbo modding pictures above that :/
And max I will be adding to the braces and incorporating into the roll cage too so the chassis is all space framed sort of thing
That didnt load before! Swear! Honest! :lol:
Looking forward to seeing this finished as you have done some real nice work so far.
Keep up the good work
Edited by S Line Automotive
Awesome build. Good to see someone doing something different with a bready. You have some serious skills :-)
moreeeeee updaterzzzzzz
so been working hard friday night right into the evening from after work
cross braces added in to the cross braces lol to mount all the rear diff mounts
should be enough to hold the rear diff in place and will have it sitting as high as poss so the car can be as low as poss I'm aiming for sills practically on the floor :)
rear diff with mounts on
rear diff mounts i made out of box section
also sorted alot of the garage today and did some work on my clio but thats just my daily and isnt as exciting as the POLO
I'm a qualified welder actually just my welder at home plays up sometimes its only a hobby one and its more than good enough i go over the welds a second time usually to double up for extra strength
this is gonna be the most pikeyd up polo I've ever seen, but its gonna be fucking awesome hahaha
its not pikey what you chatting bout
its just a load of scaffolding with bits of cars bolted to it. its savage lol! love it
its not scaffolding lol thats proper strong steel tubing used for strength applications in the engineering and building industry the place i buy it from is at the end of the road from my work and they sort me out when i want stuff its 3mm thick wall
and your right it is tubing with a car chassis welded to it but its all part of the space frame and lots of strength dont want this chassis twisting with all the mega powaaaaaaarrrrr
Main hoop bottom brace welded in
the welding for Harris
REAR DIFFERENTIAL INNNNNNNN!!!!!!!!!!!!!!!!!!!!!!!!
Passenger driveshaft on ready work sorting out new suspension mounting
driveshaft level
diff sits really low may need to raise it somehow i have some ideas but i will see how it pans out
if the diff sits on the floor then the sills will be 2 inches off the floor thats how low it is
so if i ran with the diff an inch off the floor the sills will be 3 inches high its a compromise AWD or stupid low
I could maybe raise the diff about an inch at the most ideally without changing the whole mounting so i will just wait and see how this is for a start
thats all for now just waiting for my custom alloy topmounts to turn up so i can fabricate some steel top mounts to weld into the frame to mount the ally ones too then suspension can go on and i can start sorting the bottom tca's and strut bars looks like i may need to make a little subframe to mount these too for extra strength
also received my 1.5mm decomp plate today in the post so I'm slowing getting everything together and ready for the turbo conversion
more updates to come this weekend
Edited by StinkyPete
Should of mocked it all up on the diff, set the height then tacked it, removed diff and welded in properly ;) That way you could of set the diff height :p Pikey arse hahahah.
No it's not that it's there isnt a lot of ways I could mount it And the mountings in the car are fine it's the frame on the diff and the fact I can't really have the diff in the car so it has to be under the floor pan so there is limited space anyways
I have a way to raise it about an inch but then that will be at the highest I can have it mounted its not how I've done it that's the problem it's just how it is as the diff is quite thick/high 25-30mm so it's chunkier than the petrol tank and because it can't be solid mounted I have to fit the mounts inbetween it and the chassis too
What was stopping u from welding the bars higher up? If you are doing all this anyway it wouldnt hurt to modify the floorpan
what was stopping you coming down from the turrets so the weight is transfered that way rather than just up in the middle with no spreader plates like it is or building a:
\ ___ /
/-----\ shape frame from the cage to turret mounts down and legs up or simple just a box section with a step or just a simple /--------\ welded intop of the chassis legs instead of ______ from side to side inbetween....
Also... that position isent ride height is it? so driveshafts will no longer be level, should of got it all mocked at ride height before ''welding'' it in. I'd personally sort that welder too..... :-D
Edited by POLOMON
