Mk2 4wd 16vt Bready
4MM Steel onto 2mm steel
Up your welding game bosssss! ;)
  • Replies 1k
  • Views 110.9k
  • StinkyPete
    StinkyPete
    right best do a bit of an update no pictures though unfortunately as still no laptop currently building the car up for a full mock up and making sure everything fits and clearance for whats needed.
  • brycewilson
    brycewilson
    Any new pics of this?
  • harris.racing
    harris.racing
    Who taught you to weld?
The welding is fine
And it will be linked into the main frame
I also couldn't mount it off the turrets as the diff needed to be in so I could work out where the new turrets at going as it will now be 10cm wider track either side
I also need to mount as much into the chassis to incorporate the chassis into the frame especially for the sva test
Otherwise i should have just made a full space frame and put the shell on top which is not what I wanted as that would just be a kit car with a polo shell
I want it to stay a polo so am mounting as much to the chassis as I can and strengthening it everywhere needed
The welding is fine
Well, you seem to know how you wanted it so good luck :D Hopefully see you at a show in the not so distant future ;)
By the way I'm not ignoring people's advice
There is a certain way I want to do things for certain reasons that's all
And Ben I will be adding spreader plates to the chassis rails where the bars go across don't worry I'm just trying to get the main bits done ATM
And nearer crimbo I am going to try and get an industrial mig welder to replace my hobby mig :) its just they are very expensive £450 plus so I need to get funds together for one and il also be purchasing a tig welder too ;)
I start my level 2 ally tig welding course tomorrow night all being done off my own back
And my ally top mounts are in th post on their way to me so I can get started on the rear suspension mounting later on this week
But I'm losing most of this weekend as I'm taking the misses upto Sheffield for Uni so hopefully il still get some done Sunday afternoon when I get back
Arc welder is so much better!
I mention the diff thing as 1 post you say you want sills preety much laying (a plan) then when you put it into practise it isent achieved and given you've remade you whole floor theres no excuses :p
I ment spreader plates under the horizontal bars between the chassis legs so they dont just pull out the rails.... I'll wait til its done to see how its done then :D
Good luck with the TIG course :D So long as its preetier than your mig... :lol:
Get worr lass unt train, manz got stuff gwarnin!
Edited by POLOMON
TIG is by far the best welding technique, slow it may be but if a jobs worth doing, its worth doing to the best possible level, and with TIG you get the most penetration of the parent materials.
I actually prefer ARC/MMA welding to MIG too eric, there's just something about MIG i can never get on with.
Sheffield uni you say pete, she starting there this year or something? I start on 2nd of OCT
I have an arc welder also I'm just not a fan of it I prefer MIG and I have done TIG before at college I have a level 1 in it I just want to take it further
I would prefer to have spreader plates underneath the cross bars but I will add them in to still strengthen across the chassis rail I have a way tht will work and will also be a mounting place for something else :)
Also the cross braces I put in have replaced strengthening that was already in the floor pan so they needed to be where they are so it's not as if I could have mounted them higher as it would compromise the shell rigidity
So it's like I've said that's not the problem for the diff height it's the lack of space available
And if it's not stupid low then oh well it's still gunna be 4wd and that an achievement anyway
Max she goes Sheffield Hallam and this is her last year
But I am up there this Saturday ;) and I take it you will be doing engineering at uni yeah
I want an arc welder. Hook me up haha
Buy a TIG welder thats capeable of ARC welding eric, only £550 for the one i bought! lol
Best investment i ever made.
550 is alot more than like 70 lol
I thought a tig welder was predominantly for welding aluminium and stainless?
Max that's the type of tig welder I will be buying send me a link and Moustache that is what tigs predominantly for
Because its more controllable it is widely used when welding aluminium yeah, stainless can also be quite difficult to weld if its not uber clean,
Its absaloutley piss to TIG weld soft or bright steel, mild too.
Its one of the R-tech welders, google them. Two years garuntee too.
Mint! i love projects that are different to all others. I'm watching every step of this ha
So surely a mig is best for steel, just wandering why people use the tig for it, i guess its personal preference?
Define "best"?
Its hard enough to properly TIG weld aluminium, MIG is even harder, for lesser results.
Stainless is also tricky.
Define "best"?
Best as in neatest and most penetrable, never had a go a tig welding myself so i don't know lol
Well best would be TIG everytime, neatest and has most penetration.
Good luck with SVA
Good luck with SVA
will not need one as it is a road registered car, if it passes an MOT then he is game on.
Edited by S Line Automotive
I will need an SVA as I have changed so much
And it should be fine with the SVA if it fails on anything then I sort it out but il have someone who knows about this stuff check it over first
Just watched last nights new series of "Wheeler Dealers" they put an AC Cobra kit car in for the SVA £400 :smirk:
Will you be gutted if it's slower than it was on carbs cause there's approx thirteen thousand tonnes of box section/tube?
